Caliper bracket torque?
Discussion in 'Gen 4 Prius Technical Discussion' started by rlecastro7, Mar 21, 2022.
  1. rlecastro7
    rlecastro7 Junior Member
    2018 Prius
    Hi there, i changed the front pads and rotors today on my 2018 regular hybrid prius. I'm just confused on what is really the torque spec for the caliper bracket? Is it 79 or 101. I torque it to 100. If it's over torque will something break?
    Thanks
  2. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    Hi - interested in how many kilometres you got out of the originals?
  3. rlecastro7
    2018 Prius
    115k kms. Mine didn't wear out evenly. The outer pad still has a lot left but the inner wore down. I just never checked my brakes before
    alanclarkeau likes this.
  4. Mendel Leisk
    38,751
    Torque info you need in the attached: 79 ft/lbs for the caliper bracket bolts.
    rlecastro7 likes this.
  5. rlecastro7
    2018 Prius
    Thanks. I torque mine to 100, do you i damaged the bolts?
  6. rlecastro7
    2018 Prius
    Also where can i get this manuals?
