Caliper Diagnosis & replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Bill Bruck, Mar 4, 2017.
  1. Bill Bruck
    Bill Bruck Junior Member
    25
    I took my 2010 Prius in for an airbag recall. I guess as a result of a courtesy inspection, they told me that one caliper needed to be replaced. (Nothing was put on the ticket about this, and I don't know which caliper it was.) I was told that they pretty much always replaced at least the left and right, and it might be better to do all four for $1,500. I took the car to Firestone for a second opinion. They said there was no fluid leak, LF and RF 7mm; LR 4mm and RR 5mm for pads. They also said they could not tell if the caliper was bad without getting air in the lines, and they didn't have the tools to purge it (so they could not replace the calipers if asked, which would have been $1,150 rather than $1,500 if they had the right tool). I've read here about 2010 Prius calipers being frozen, and I have some questions...
    1. Could one of my calipers be bad and there are no signs of it during normal driving?
    2. If one is bad - I guess frozen - why would you need to replace the other side? Is it important to replace both L and R? Is it important to replace all four?
    3. I have no idea how the dealer was able to diagnose this during a courtesy inspection. Do dealers have a tool that allows them to test if a caliper is bad without then purging air out of the lines, which they certainly did not do? Could they have been saying this because of the 1mm pad thickness difference?
    4. Is $1,500 for four calipers reasonable? Is Firestone's price (which they can't do anyway) of $600 rear and $550 front reasonable?
    Any advice for me?
  2. StarCaller
    StarCaller Senior Member
    1,271
    723
    Cedar Crest, NM, USA
  3. NavyLCDR
    NavyLCDR Active Member
    201
    125
    Lebanon, OR
    2024 Prius
    XLE AWD-e
    The biggest way to tell if a caliper needs to be replaced or not is to look for uneven wear of the inside and outside brake pads on that caliper. Many times just taking it apart and cleaning/lubing the pins the caliper slides on is enough. If one caliper piston was stuck and not applying the brakes on that wheel then the brake pads on that wheel would be worn much less than the others around the car. Since all of your brake pads around the car seem to be even, I'm wondering too how the dealership determined a caliper is bad.
    #3 NavyLCDR, Mar 4, 2017
  4. ChapmanF
    17,341
    I would love to think that they did do this, it turns out to be valuable diagnosis to do and can quickly identify two different failure modes for calipers, one where the piston gets outright bound up, and another where it moves smoothly enough but doesn't retract by the proper fraction of a mm when the brakes are released.
    In the thread linked above, I was doing the test on the bench with caliper removed, but I think it should be possible in situ and without introducing air, and I've suggested a way to do it—though I'm still waiting to hear from anyone who's tried it. Would only need some hose, a bit of compressed air, some blocks of a hard material with holes drilled through, and a dial indicator with a suitable-length extension, and a small amount of make-up brake fluid.
    I would love to think the dealer did this test, but I'm confident they didn't, and generally wouldn't, as courtesy checks wouldn't involve anything with even that much labor.
    It's certainly in reach of a DIY-minded owner, though.
    -Chap
    p.s. any problem you do find with a caliper, unless severe, can likely by cleared up by a simple go-over of the caliper you've got with a new rubber kit from Toyota. Another thing a dealer isn't likely to do, because their tech is done with the job faster by slapping in a new caliper out of a box. DIY, though, it saves you both the overkill of a new caliper when it isn't needed, and the irony of replacing a quality original caliper with an often cheaply rebuilt third-party one.
    -Chap
    #4 ChapmanF, Mar 4, 2017
  5. bisco
    51,148
    how many miles on her? are you in the rust belt?
  6. Jimi1976
    Jimi1976 Active Member
    242
    124
    Denver, CO
    I would ask them what makes them think there's a frozen caliper....? Rotors are even left>right......
    Do you have any mpg loss indicating brake drag?
    Dealers suck.
  7. Mendel Leisk
    40,581
    Dealership is not being very forthcoming. They say there's a problem with one caliper, but don't volunteer which. Or what the problem is exactly. And make the suggestion to replace all four?? I can kinda see to replace either front or rear pair, but...
  8. JC91006
    16,673
    8,518
    I would ignore the recommendation from this dealer. They need you to help pay for their boat payment
  9. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,601
    1,691
    Bay Area
    For calipers, you don't have to replace them in pairs, you just replace the one that is frozen. To determine if the caliper is frozen, you want to check if the piston moves in and out or not, uneven pad wears more indication of frozen sliding pins.
  10. ChapmanF
    17,341
    It's pretty easy to notice a piston that flat-out won't move (or that you need a C clamp to move, even with the bleed screw open), or flat-out stuck slide pins.
    It's a little more involved to check for a piston that moves easily enough, but just doesn't have the proper return when the brakes are released. It's only about a third of a millimeter. (That is, just, visible to the naked eye if you're really watching for it, but a dial indicator will make it obvious.)
    On the other hand, if you have a test method able to reveal lack-of-return, it will also be able to reveal a stuck piston. Both things do happen; lack-of-return was the whole explanation for a brake-drag issue I had in 2015—and that was on a newly-installed, 3rd-party reman caliper right out of the box, so the test is worth doing.
    -Chap
    jdcollins5, Raytheeagle and Samprocat like this.
  11. Former Member 68813
    3,524
    983
    US
    I just regreased brake pins second time after 40,000 miles since the first time, and some of them were hard to move (the grease hardens and yes, I use the proper OEM grease). When i was younger and not familiar with cars I did pay for a few "frozen calipers." In retrospect, it could be avoided by simple pin greasing.
  12. Jimi1976
    242
    124
    Denver, CO
    Hey OP....what ended up happening?
