"Caliper Pin Lube"......
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Tande, May 26, 2021.
  1. Tande
    Tande Active Member
    502
    302
    Mich.
    Anyone use this on caliper slide pins? ......I tried & it swelled the pin rubber bushings......same thing when I used it on my kitchen/faucet O/rings (it takes two men & a boy now, to swing the faucet! )....:mad:
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,173
    2,213
    Taylors, SC
    I use this stuff to lubricate the sliding metal parts.
    I do not, however, use it on the rubber parts. For that I use pure silicone dielectric grease,
    For plumbing o-rings I use Vaseline petroleum grease.
  3. ChapmanF
    15,663
    The fact that Toyota over and over and over tells us just what stuff to use for that
    seems to inspire an amazing number of threads on PriusChat about what stuff to use instead.
    The Toyota-specified stuff, for what it's worth, is not a silicone, it is a glycol base, lithium thickened.
    A little packet of it comes in every Toyota caliper rebuild rubber kit, so there's often no need to buy a tube.
    Valiant V likes this.
  4. farmecologist
    farmecologist Senior Member
    1,951
    1,786
    Southern MN
    Pulse07 likes this.
  5. ken2116
    ken2116 Junior Member
    37
    16
    Northern CA
    2019 Prius
    I've used it on other cars (Civic, Subaru, Lexus, Mercury) w/o problems, but thanks for the head's up and will use whatever Toyota recommends on the P. On water faucets use only lubes known to be non-toxic - purchase "Plumber's Grease", there are conventional and silicone versions, both work.
    Tande likes this.
  6. brenthon
    brenthon Junior Member
    GA
    I use Permatex Ultra Disc Brake Caliper Lubricant.
  7. thomassster
    thomassster Member
    239
    82
    Colorado, US
    2019 Prius
    XLE AWD-e
    Cause there are rubber parts surrounding the caliper pin, it requires a grease that can handle non metal. Silicone is best known for that, but that Toyota rubber grease probably works as well. Not sure why so many greased advertise for calipers when many times there are rubber components surrounding it on the rubber bushings or some rubber on the pin itself.
    farmecologist likes this.
  8. farmecologist
    1,951
    1,786
    Southern MN
    Yep...3M silicone paste all the way. (y)
  9. Tande
    Tande Active Member
    502
    302
    Mich.
    Same as post #1? .....
