Calling all prius gurus. This is a head scratcher. Ready light only stays on for less than 1 secon
Discussion in 'Gen 3 Prius Main Forum' started by andy song, Jan 6, 2023.
  1. andy song
    andy song Junior Member
    Just purchased a 2011 prius from Arkansas
    Previous owner said car drove fine until the hybrid battery went out. Car sat in his yard for 2 years
    I brought it back home and pull my hybrid battery out of my 2010 prius and put it in his. His 12v was dead as well so i swapped that with my 12v. My 2010 prius runs and drives so i know both batteries were good
    The ready light would come on for a second and the dissappear. The notification on the dash says check hybrid system. When i scan the code the only thing that shows up on Dr. Prius was U029A: Lost communication with hybrid Battery Pack Sensor Module
    I check the connectors to the battery pack. Clean. No corrosion
    Then i pop open the fuse box and see 3 wasp nests (i attached photos)
    I pulled all the fuses and relays out and sprayed everything down with electrical cleaner. Blew air all over and let things dry up really good and put all the fuses back (i did check each fuse to make sure they are all good)
    Same thing. Car goes into ready (i can hear the hybrid battery relays click in) and then in less than a second the ready light dissappears and i get the check hybrid system notification on the dash
    Any ideas what might be causing the u029a code?
    Thanks
  2. Leadfoot J. McCoalroller
    7,135
    6,683
    Pennsylvania
    2018 Prius c
    A broken wire with a clean connection doesn't count. Might need to trace those lines with a meter, maybe look for rodent damage.
    Tombukt2 likes this.
  3. Tombukt2
    Tombukt2 Senior Member
    8,920
    1,553
    Durham NC
    Mud dobbers . That mud that they bill their houses out of like Adobe that stuff will go down inside of the slots in the fuse box It is like sand it is an abrasive so you need to make absolutely certain that your electrical contact cleaner or WD-40 blast into those slots where the fuse is go and pushes up the mud and grit out of those slots it's not just a spray clean and blow operation You might have to get a shop vac so you may want to use WD-40 as it's not flammable and things won't create havoc with the Shop-Vacs motor brushes sparking whatever and after you douse that real good have your Shop-Vac right there at the ready to suck that wetness and abrasive out of those slots If you push fuses in and feel the abrasiveness and the squeaking noise you haven't got it all that could be standing the fuse off enough to not make good contact just a thought mud daubers are no joke they can clog up a pressure washer wreak havoc on an engine all kinds of good stuff that mud you're looking at is brittle and breaks easily but boy does it stick and wreak havoc on almost anything I've seen $1,000 of equipment ruined by mud daubers just one summer from it sitting when I take my pressure washer out in North Carolina every summer they have made houses in the wands of my pressure washer on the intake piping where the water is going to go completely blocked I have to make sure I bring this equipment out spray it off with a garden hose first get the mud saturated and then put the nozzle on a thin blast just from the garden hose and make sure all that mud is gone so water can get into the pressure washer get pressurized and then squirt out the nozzle I've seen my pressure washer wand not able to push the thousand plus PSI water out of it just with mud daubers mud in the wand not even in the yellow or red or green click on tips just the tube of the wand It will keep that water from coming out and your pressure washer from working so make no mistake You have got to get all that stuff out of there. And then of course since you've had your batteries out and you're swapping them we know that there's no buildup or frost or corrosion on the bus bars and nuts? Then proceed from there
    49,387
    did you complete the 3 steps of the orange safety plug?
  5. JC91006
    16,477
    8,394
    Check all your fuses, make sure EFI fuse is not broken
  6. PriusCamper
    PriusCamper Senior Member
    11,062
    4,504
    Pacific Northwest, USA
    Those codes are because one of your ECUs isn't communicating... Once you've run out of wires to inspect, check for critters inside the ECUs and then start swapping them out with the ones from your other Prius. A used ECU if you need to replace it isn't very expensive.
