Calling all Prius V owner's with Michelin tires!
Discussion in 'Gen 3 Prius Main Forum' started by swich2mac, Aug 16, 2009.
  1. swich2mac
    swich2mac Go Hard or Go Home!
    319
    38
    Franklin, TN
    I have yet to fool with tire pressure settings since taking delivery on my car 3 weeks ago. Can you all share with me what pressure you have your front & rear set to and any MPG changes by doing so?
    Thanks,
    Scott
  2. LS5099
    LS5099 Junior Member
    Hemet, CA
    2018 Prius
    Scott:
    I have a 2007 Prius. After going thru the OEM tires in 22K miles, I put on a set of Michelins. I have 27K miles on them and they look like they can go another 20K. I am running 42 PSI in the front and 40 PSI in the rear with no unusual signs of tire wear on the outer edges. I immediately noticed a 2 MPG increase doing so.
    DogDaze and SFguy2009 like this.
  3. Blind Guy
    Blind Guy New Member
    352
    194
    Springfield Missouri
    I posted a Thread on this a while back when we first picked up our V which was equipped with Michelin's, and I discovered the Michelin's are EXTREMELY sensitive to tire pressures and their effect on ride comfort.
    I explained that the Dealer pressures were set at 37.5psi Front and 36psi Rear, which gave a firm, yet sporty ride on the 195 mile trip home. Once arriving home I decided to try higher pressures (39psi Front and 38psi Rear) to possibly improve mileage, the ride at those pressures was bordering on harsh. I then set the pressures at 35psi Front and 34psi Rear, the ride was somewhat soft. So we finally settled on pressures of 37psi Front and 36 Rear, which gives a ride that is quite comfortable yet gives an ample amount of road feedback and better performance.
    I am unable to give you any input on its impression on Fuel Economy because we've logged less than 400 miles to this point.
    David (aka Blind Guy)
    MrJamtastic and DogDaze like this.
  4. warrior
    warrior New Member
    141
    Paso Robles, CA USA
    My manual suggests 42-40. Good enough for me:)
    DogDaze likes this.
  5. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    What kind of manual suggests 42-40? I must have missed that one.
  6. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    Hydroedges, still have 3 out of 4, have been somewhere over
    50 PSI all their life. 60K on them so far and still plenty of
    tread left all the way across.
    _H*
    DogDaze likes this.
  7. alanderego
    alanderego Member
    87
    26
    Honolulu, Hawaii
    Your best bet is to go with the tire pressure recommended by the door sill sticker.
    That is your safest bet.
    My 2010 V says 33 front and 32 rear.
  8. kash
    kash New Member
    Houston, TEXAS
    are yall all using AIR? i was thinking about doing N2 fill in them like my hybrid RX
  9. gil
    gil Junior Member
    83
    Richmond, VA
    Mine had about 38 to 39 PSI as delivered from the dealer. I set them at the sticker pressures of 33 front and 32 rear. The ride comfort improved and were reasonably quiet at these pressures. I plan to check the pressure often as these are known to wear quickly.
    DogDaze likes this.
  10. alanderego
    alanderego Member
    87
    26
    Honolulu, Hawaii
    For the N2, Don't they put on the green valve caps?
    DogDaze likes this.
  11. kash
    kash New Member
    Houston, TEXAS
    yeah they do, just wondering if anyone changed the air to Nitrogen
    DogDaze likes this.
  12. compac
    compac PSU, Metallic Blue Ribbon
    52
    VA, Blue Ridge mtns
    We run 789.5% N 19% O seems the comb workd fine. :rolleyes:
  13. Much More Better
    Much More Better Active Member
    655
    163
    Nitrogen is the biggest scam in the auto industry.
  14. ImeanGreen
    ImeanGreen Prius v Five BP Brigade #236
    547
    73
    Somewhere out there
    There is some truth to the use of nitrogen. Nitrogen air is more stable than regular air. It maintains air pressure on a consistent basis. Regular air tend to expand at higher temps and deflates at lower temps.
    DogDaze likes this.
  15. Fore
    Fore Don't look back!
    494
    107
    Oh boy here we go again!!!
  16. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    420
    Whereabouts Unknown
    I use between 78 and 79 percent nitrogen in all of our cars. It provides excellent performance and tire life, and is thrifty.
    DogDaze likes this.
  17. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    If worried about the Oxygen permeating out so much, put 28% extra regular air (which is 78% Nitrogen) in your tyres, wait for the oxygen to permeate out, then you have 100% nitrogen left.
    E.g. if tyre pressure should be 33 psi, put 42.5 psi in, 22% of that (the oxygen) permeates out, leaving 33 psi. (28% addition equates back to a 22% loss) ;0)
    I haven't a clue how long it would take to achieve this but after nearly 40 years of driving, I've found that, apart from temperature fluctuations (and leaks of course), tyre pressures tend to settle after the first few checks, probably a couple of months if that.
    To the OP, I find an extra 2-3 psi up on standard pressures a good compromise. It gives the steering a sharper feel without adding too much harshness to the ride, mpg is pretty much the same as standard.
    DogDaze likes this.
  18. rjparker
    rjparker Tu Humilde Sirviente
    7,918
    4,680
    Texas Hill Country
    I run the factory recommended low thirties in my Michelins. The ride is fine, the mileage is spec and their life is at least 80,000 miles. I have gotten up to 95,000. If you think about the dollars saved by eliminating half of the tire purchases, those dollars are just as good as jacking up the pressures for two mpg while rattling your brain and everything in the car including the hybrid battery.
  19. DogDaze
    DogDaze Member
    173
    36
    Bay Village
    I did when I put new tires on.. they use Nitrogen at Costco.
    I can't find the same:
    Michelin® ENERGY SAVER P205/60R16 91V
    as it's been discontinued..
    the replacement is:
    Michelin® ENERGY SAVER P205/60R16 92H
    and the price went up another $200 for a set of 4 since I last replaced these. (still on my 2nd set as of now)
    I'm curious as to what other tires folks have moved to these days and how you might like the other options?
  20. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
    Strange how these 10 yr old threads pop up as newly updated on TapaTalk. I've replied to several by accident myself...
    REVVL V+ 5G ?
