Calling all wheel clearance experts: picking out wheel/tire size
Discussion in 'Gen 3 Prius Accessories and Modifications' started by HeinzCatSoup, Oct 2, 2013.
  1. HeinzCatSoup
    HeinzCatSoup Junior Member
    Southern California
    Hey guys, i'm looking to purchase these
    18x9.5 +34 - Someone on the forum, I forget who, has this exact wheel setup and I've asked about rubbing, but never got a reply. Atleast they seem to fit. Should I go for a different fitment?
    Anyone know how this would set up with probably a 215/40/18 stretch setup or a 225/35/18 setup? Probably going to be lowered on coils. Hopefully get this done by the end of the month.
    Anyone have a better setup for a stretched tire look (without being too extreme)
  2. HeinzCatSoup
    Southern California
    Also anyone think 9.5 is too wide?
  3. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :)Yup, I do. Buy a set that will fit, versus a set you make fit. Wheel offset is always a hassle. I couldn't live with the factory 15" wheels on my Prius. I like the Prius 5, 17" wheel. I like the look and it fits without question. That's what I went with. Plus, my Prius still functions like a hybrid.
  4. HeinzCatSoup
    Southern California
    thanks for the reply. I just want to make sure it clears those brakes.. because nothing saddens someones day than finding out they bought shoes that dont fit. :(
  5. xliderider
    xliderider Senior Member
    8,056
    3,223
    Honolulu, HI
    Not only does it have to clear your brakes, but all suspension components, and lastly your fenders.
    You mention you want to drop in some coilovers, the wide wheels may not clear the fenders. Unless you are comfortable with pulling or rolling your fenders/wheel wells to gain some clearance, I'd avoid wide wheels.
  6. andino
    andino Senior Member
    746
    550
    San Jose, CA
    Rears will be fine. Fronts will rub and need a slight pull to fix that. I ran 18x9.5 +38F and +33 rear on 225/40s and rears are no problem. Fronts rub on big bumps. Even my current setup rubs slightly on bigger bumps but only on the liners. With a 215, you can get away with the more aggressive offset.
  7. HeinzCatSoup
    Southern California
    all these comments are helpful guys. so quick update.. wheels have been bought. now to figure out what size tires to get.. also fenders will most definitely be rolled.
  8. peterjmc
    917
    189
    Clarksburg, MD
    From what I gathered, there isn't much rolling you can do to the front fender. You just need to have them pulled. The front fender lips are folded up pretty well from the factory from what I could feel.
    HeinzCatSoup likes this.
  9. bino
    bino JDM ZVW30
    1,348
    706
    SoCal 91739
    that is correct.....
    I had my fronts rolled/pulled and I installed camber bolts.....
    on the rear... I had it grinded instead of rolling it.....
  10. HeinzCatSoup
    Southern California
    since you're in socal, know any professional shops that can help pull the front fender? or should i just roll up my sleeves and do it myself.
  11. bino
    bino JDM ZVW30
    1,348
    706
    SoCal 91739
    I would suggest having it done by someone who knows rolling pretty well.....
    google 'Tony fender rolling 818'...... he's the guy that work on my cars and some of my friends cars..... he's known on many forums as the guy to go to when you want you're fenders rolled / shaved properly.... (y)
  12. peterjmc
    917
    189
    Clarksburg, MD
    +1 I would not pull or roll a fender if you haven't done it before. It would be very easy to deform the fender and make it look lumpy without proper technique/experience/tools.
