Camping power source?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Gilbert, Jun 20, 2017.
  1. Gilbert
    Gilbert Member
    255
    going camping... thinking of using my Prius to run a fan or something inside tent cause it's going to be very hot this weekend.
    What kind of power draw limitations do I have?
    Can it power an average house size fan?
    What do I need to make this happen? Something like this would work?
    Foval 300W Power Inverter DC 12V to 110V AC Converter with 4.8A Dual USB Car Charger
  2. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    i would buy a battery operated fan than to risk draining car battery or carvon monoxide poisoning
  3. jdenenberg
    jdenenberg EE Professor
    3,943
    1,940
    Trumbull, CT
    2020 Prius
    LE AWD-e
    You can safely pull 1000 watts (about 80 amps) from the 12v bus when in READY mode. The 12v battery can be quickly drained if you use 12v when your Prius is off.
    JeffD
    #3 jdenenberg, Jun 20, 2017
  4. wjtracy
    wjtracy Senior Member
    11,368
    3,608
    Northern VA (NoVA)
    Jeff?? 8 amps?
    jdenenberg likes this.
  5. William Redoubt
    William Redoubt Senior Member
    1,228
    1,172
    Coronado Island, California
    There is virtually zero danger of CO poisoning with the car in ready mode. The engine will only start once an hour at the most, and then for a couple of minutes.
    Put the inverter as close to the 12 volt battery as possible and use an appropriate household extension cord.
    I use a 750 watt unit from Harbor Freight with an outlet inside the car for coffee, lunchbox oven, 1.5 cup rice cooker, soup warmer, etc. It can also run a power drill, soldering iron, etc. The inverter sits snugly above the under the hood fuse box. I have it wired to control the off/on function from inside the car to avoid patristic drain.
  6. jdenenberg
    3,943
    1,940
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Oops, lost a zero. Fixed above.
    JeffD
  7. wjtracy
    11,368
    3,608
    Northern VA (NoVA)
    Jeff thank you 80-amps!
    The reason I reacted is that some new Gen4 folks do not seem to be aware of this potential to get a lot of amps. No reason why Gen4 is different right? Except perhaps less accessible 12v location under the hood.
