Camry 2009 With Inverter And Hybrid Codes COVID 19 Sitting
Discussion in 'Toyota Hybrids and EVs' started by ScottCamry, Jul 11, 2020.
  1. ScottCamry
    ScottCamry New Member
    Towson MD
    Light Blue Camry 2009 With 209K Miles The Car Has Been Sitting Since March 21St and started it up July 7Th the 12v was dead so I jump started it and it worked then I rested the codes so but the 12v died again after driving about 3.2 miles so I need some options I was able to get it. to Toyota but they came gave these codes so I need some options on what to do thanks!
    I’m In Towson Md
    P0A80 - Replace Hybrid Battery Pack
    P0A7F - Hybrid Battery Pack Deterioration
    P3013 - Battery Block 3 Becomes Weak
    P3000 - Battery Control System Malfunction
    P0AC1 - Hybrid Battery Pack Current Sensor 'A' Circuit Low
    P0117 - Engine Coolant Temperature Circuit Low Input
    P0301 - Cylinder 1 Misfire Detected
    P0A7A - Generator Inverter Performance
    P0A78 - Drive Motor 'A' Inverter Performance
    P0A12 - DC/DC Converter Enable Circuit Low
    P0A09 - DC/DC Converter Status Circuit Low
    P0A94 - DC/DC Converter Performance
    P0A93 - Inverter 'A' Cooling System Performance
    P3004 - Power Cable Malfunction
    C1310 - Malfunction In HV System
    C1242 - IG2 Power Source Circuit
    C2318 - Low Or High Voltage Error Power Supply Malfunction
    C1259 - HV System Regenerative Malfunction
    B1424 - Solar Sensor Circuit Driver Side
    #1 ScottCamry, Jul 11, 2020
    49,490
    welcome!
    depends on your wallet, time, desires.
    you can buy a new oem battery, look for a good salvage, go with a questionable rebuilt, or rebuild it yourself.
    that's all assuming that toyota checked the 12v health before reading the codes.
