Camry Hybrid mpg
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Rybold, Feb 15, 2012.
  1. The Camry Hybrid's mpg exceeds what I would expect from this car.
    4 vote(s)
    30.8%
  2. The Camry Hybrid's mpg is about what I would expect.
    4 vote(s)
    30.8%
  3. I would expect better mpg from the Camry Hybrid. I'm somewhat disappointed.
    5 vote(s)
    38.5%
  1. Rybold
    Rybold globally warmed member
    2,760
    322
    Southern California
    UPDATE: THE PHOTOS BELOW ARE OF THE XLE MODEL, WHICH GETS 40/38mpg. THE LE MODEL GETS 43/39MPG. I JUST REALIZED THAT. SORRY.
    Over the weekend, I got to see the new Camry Hybrid, and I took some photos of the window sticker for your enjoyment. The car looks really good! Check out the MPGs!
    Thoughts?
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    I got to drive the '12 HyCam briefly at Green Drive Expo last year. I was pleasantly surprised to hear the much improved EPA estimates over the previous gen while upping the power and improving rear trunk space. It makes the Prius v wagon's mileage seem disappointing given it has much less power.
    From some "bench racing", it's just about as fast as the now defunct NAH.
    49,448
    why does the le get better mileage?
  4. Rybold
    2,760
    322
    Southern California
    Both the LE and XLE have the exact same engine, rated at the exact same horsepower.
    The LE has 16" steel wheels. The XLE has 17" alloy wheels.
    The LE is 90 pounds lighter (LE=3435lbs, XLE=3525lbs).
    All the other specs appear to be the same (I performed a side-by-side comparison on the Toyota website, see link below).
    LE = 43/39/41 mpg. XLE = 40/38/40 mpg. (city/hwy/combined)
    SOURCE: http://www.toyota.com/camry/specs.html
    (great website, btw!)
  5. austingreen
    austingreen Senior Member
    13,574
    4,114
    Austin, TX, USA
    That seems to indicate rolling resistance is the primary difference, but only is about 1 mpg combined. Hwy mileage is likely almost the same, but one rounded down the other up:cool:
  6. DeadPhish
    DeadPhish Senior Member
    2,010
    353
    Outer Banks of NC.. Retired to play golf and poker
    Most XLE's come with a sunroof standard. The extra weight of this might increase the weight along with the larger wheels. Automakers often have intra-company fights over increases of 1 or 2 lbs of additional weight.
  7. bisco
    49,448
    funny, when i asked why the prius touring showed same epa as regular prius, i was told testing was a generality and same numbers go on all the vehicles.
    when we bought our 08 hycam, xle and le had same numbers i believe, but i could be mistaken.
  8. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    they clearly did it differently, probably because XLE gets more than a minor share of the market... so they tested both versions.
  9. Tideland Prius
    16,150
    That was then. This is now. I'm starting to see more "split numbers" between the base and higher model. Honda Canada does it with their Insight and Fit. The lower models have one FE rating and the top model has another because of different wheel sizes and/or bodykits.
  10. bisco
    49,448
    thanks, that's good news, more info to help decide between models. now i'm wondering if we had purchased the le if we would be getting even better mileage than the 35-45 we get now.
  11. hill
    8,172
    My Prius driving car pool partner just got the hy cam for his wife. He / we discovered (talking about the sunroof) that you do NOT get lighted vanity mirrors on the sun visors unless you get the sunroof. His wife is P.O.'d about not having the vanity mirrors. They bought, XLE ... but they didn't want the extra cost of the sunroof. How's THAT for a weird arrangement of accessories.
    :p
  12. fotomoto
    fotomoto Senior Member
    5,602
    3,778
    So. Texas
    The US Toyota website shows identical mpg's for all three sizes of the Tacoma truck line with the same engine/trans/rear axle ratios yet growing 17 inches in wheelbase and 400 lbs. Toyota has defied the laws of physics! ;)
  13. bisco
    49,448
    that's brutal. the one thing that drives me crazy about toyota is the way they change option accessories on new model packages.:( when they figure out that an accessory is popular, they move it up a package.
  14. Rybold
    2,760
    322
    Southern California
    That's why it's a good idea to test drive, sit in, and inspect the ACTUAL vehicle you will be buying BEFORE you buy it. :)
    p.s. (because I can't resist :p) talk about VANITY!!!
  15. austingreen
    13,574
    4,114
    Austin, TX, USA
    My back seat has rarely been used, except with it folded down for bikes. The passenger's vanity mirror gets used all the time.
    What were they thinking on a car like that? I bought a model II, because I didn't like the toyota packages on my prius and ended up adding my own stuff. It should be easier. You shouldn't have to buy leather to get big wheels or fog lamps.
    I think EPA allows you to average based on expected sales or spell out different ones for models. They want to sell the big ones and they don't need to tell you they get worse mileage. Let's face it though 17s don't make all that much worse mpg difference on a truck.
