Can’t clear C1345 On Prius v
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Carbit, Nov 26, 2024.
  1. Carbit
    Carbit New Member
    Middle VA
    Hey, all, recently had a C1391 in my 2012 Prius v. Since 1391 is an accumulator leak, I decided to replace “Actuator assembly” part purchased from the dealer and matched to my VIN.
    Replacement was done per the service manual for a 2010 Prius.
    I now have the dreaded C1345 (and sometimes 1368, depending on mood). I’ve done the bleed sequence twice on techstream, and I’ve tried the “linear valve offset” multiple times in techstream and on a thinkdiag+ with no success. Sometimes it makes all the noises, sometimes not. I’ve also done it on a 12v trickle charge…
    Any ideas? Is there a step I’m missing? Is the Prius v procedure different somehow?
    Is the “linear valve” in the actuator or booster?
    Thanks
  2. ChapmanF
    17,203
    Yes, because the actuator and the booster are the same part. :) (The other part is the "booster pump", and that extra word 'pump' is important for not mixing the two different parts up.)
    As for the linear solenoid learning not succeeding, I'm afraid I can't offer much, if it's a dealer actuator and was matched to the VIN, it oughtta work. Sounds like you've bled it enough there shouldn't be air bubbles in it by now. Maybe check if there's anything amiss with the lines or calipers that could be changing the response under pressure. This is a puzzling one.
  3. Carbit
    Carbit New Member
    Middle VA
    Ok, so what you have labeled “booster pump”, the dealership calls “actuator assembly”. The part I replaced is 47070-12020.
    So I got the pump part. Did I need the other one?
  4. ChapmanF
    17,203
    Whatever dealer called it that effed up. The linear solenoid is part of the (real) actuator assembly (the upper drawing).
  5. Carbit
    Carbit New Member
    Middle VA
    Agree. Lots of names for that part.
    Is there a possibility that there is a hardware issue? I don’t want to buy another $800 part unless it’s absolutely necessary. Thanks
  6. Mendel Leisk
    40,497
    Just an aside: the mechanical problems with these components are rivalled by the naming confusion?
    Carbit and Air_Boss like this.
  7. ChapmanF
    17,203
    True enough: each of those two assemblies can be known by multiple names. 'Booster', 'master cylinder', 'actuator', and 'skid ECU' all are names for the top one (a close look shows it combines all those things), while 'booster pump' and 'accumulator' both refer to the bottom one.
    But calling the bottom one by any of the names for the top one was just a bonehead mistake that a dealer, in particular, should not have made.
    Well, that upper part is where all the actuator valves including the linear solenoid(s) are found, and if a bunch of efforts to learn the solenoid offsets have failed and there aren't air bubbles around or any obvious problems with the lines or calipers, it would seem the finger of suspicion hasn't got a lot of other places to point.
  8. Carbit
    Carbit New Member
    Middle VA
    Thanks for sharing your knowledge. I’ve been all over this site as well as others and couldn’t find any similar situation. I guess I’m going to have to preform another Prius surgery soon.
