Can’t disconnect inverter connector
Discussion in 'Gen 2 Prius Main Forum' started by Scott Caputo, Sep 6, 2022.
  1. Scott Caputo
    Scott Caputo Junior Member
    37
    Los Angeles
    Not sure what it’s called, but it’s the big connector that plugs into the front of the inverter from underneath with the 3 bolts holding it on inside the cover, and 2 bolts that hold it on the outside. It joins the inverter just below where the part number sticker is. I have all the bolts out and I can’t separate this connector. I don’t want to pry on it too much and brake it. Is there a trick to this?
  2. Scott Caputo
    37
    Los Angeles
    Never mind, I found the tabs inside.
    Tombukt2 likes this.
