Can’t get drivers side low beam in
Discussion in 'Prius v Technical Discussion' started by kimpossible, Dec 6, 2021.
  1. kimpossible
    kimpossible New Member
    NYC
    When ever i try to put in this new bulb it never clicks in place. It will just fall out the whole of it will bust and i end up having to buy a new one. How to i get this h11 bulb to stay in place it’s housing
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,917
    4,678
    Texas Hill Country
    Use a good light so you can see the opening on the headlight housing. Normally the connector end points down once its rotated about 90 degrees. So you start rotated 90 degrees from the final position. Insert the bulb without the cable to make it easier. Make sure it fits flat and rotate down. Once its in, snap in the cable.
  3. Air_Boss
    Air_Boss Senior Member
    3,939
    1,076
    New Yawk
    If you illuminate the low beam lamp housing from the front (outside), you can see the keyed opening as the target and fit the lamp.
  4. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Also, once fitted, make sure you got it right. Turn on lowbeams and make sure you have a good beam pattern with the usual cutoff and squirrel finder rectangles of light above the cutoffs.
    A bulb that is askew will have a terrible beam pattern and should be corrected pronto or you will melt the plastic mounting area of the headlight housing.
