Can’t get rid of P0343 detail code 747: Camshaft timing circuit high input
Discussion in 'Gen 3 Prius Technical Discussion' started by HelloMcFly, Oct 4, 2023.
  1. HelloMcFly
    HelloMcFly Member
    35
    42
    Oklahoma City
    I have a car that will drive for a couple hundred miles, then the P0343 detail code 747 appears and shuts the car off. the code is camshaft timing circuit high input. After the code appears you have to disconnect the sensor and ECU to get the code to disappear then it’s a toss up as to when it will reappear.
    I’ve replaced both the camshaft and crankshaft sensors, and the code continues to appear. Note : I did have a crankshaft sensor alert appear once before.
    i can’t find anything abnormal as timing is spot on, and the wiring is intact and secure. The car ran fine for 6 months before this problem arose out of nowhere.
    Any suggestions as to where to go from here? Any help would be greatly appreciated.
  2. ChapmanF
    17,349
    The output of that sensor is supposed to stay between 0.3 V and 4.7 V at all times (it pulses between the lower and higher value as the camshaft rotates).
    The P0343 indicates that voltage above 4.7 was seen (for four seconds or more).
    One common way that can happen intermittently is if there is some wiring insulation damage somewhere between the sensor and the ECM, and it is allowing the cam sensor wire occasionally to touch something else with voltage above 4.7.
    Other than "intact and secure", what steps have you taken to test the wiring? Have you looked through the steps for that in the P0343 section of the repair manual?
    Toyota Service Information and Where To Find It | PriusChat
  3. HelloMcFly
    HelloMcFly Member
    35
    42
    Oklahoma City
    Thank you so much Chapman. I haven’t ohmed out the harness completely. When doing the swap hand a year ago I recall seeing a lot of rodent droppings.
  4. Big Al50
    Big Al50 New Member
    Kansas City
    I too have a P0343 code still after I replaced the camshaft sensor. My OBD scanner shows permanent P0343 camshaft position sensor 'A' circuit high bank 1 or single sensor.. How this this be reset for good???
  5. ChapmanF
    17,349
    Do you mean that the code is being displayed as 'permanent'?
    That just means the ECM remembers that problem existed at one point. It will hang on to the 'permanent' code for a while until you've driven enough without the problem appearing again that the ECM is convinced it's resolved.
    Brian1954 likes this.
  6. Big Al50
    Big Al50 New Member
    Kansas City
    Oh ok great. Yes, the P0343 code shows as a permanent code. I also read somewhere to clean the throttle body and possibly change the pcv value along with changing this sensor to get rid of the P3190 (low power reported) and P0343 (camshaft sensor). Thanks for this update Chapman.
