Can 2010 run on gas alone when HV battery fails?
Discussion in 'Gen 3 Prius Main Forum' started by Gen 3 for me, Mar 21, 2009.
  1. Gen 3 for me
    Gen 3 for me Member
    198
    81
    Illinois
    Greetings. I'm new to this site. I'm thinking of buying a 2010. Does anyone know if a 3rd gen can run on gas alone for extended time. I like to keep my cars for a long time and I only drive interstate miles. So when it becomes an old car and the HV battery fails can I use the car for interstate travel without without replacing the HV battery without causing a problem. Would there be some drawbacks besides fuel economy? Can the HV battery be removed for weight savings at this point in time? Has anyone on this site actually done this yet?
    I've read that the car can run on gas alone or battery alone but I don't know if my interpretation above holds true. Can I go the gas only route with a Prius when it ages, or should I buy a Corolla?
    Thanks
  2. dogfriend
    7,512
    1,185
    Carmichael, CA
    Based on the Gen 2 version, and what I know about the changes to the Gen 3 version, I believe that it will not run for an extended time (or really at all) without the HV battery. For one thing, after the car is "booted up" the HV battery supplies power to the DC to DC converter to run the 12V accessories and to recharge the 12V (auxillary) battery.
    You do know that the HV battery has either an 8yr/100,000mi warranty (standard) or a 10yr/150,000mi warranty (Calif emission states) right? So, it isn't really a huge concern for most owners.
  3. dr_d12
    dr_d12 Member
    154
    The gas engine won't start without the HV battery. When you press the start button the car only 'boots' like a computer. When the car needs the gas engine, the HV battery spins up one of the electric motors (MG1), which acts in place of a starter motor. MG1 spins the gas motor to about 1,000 rpm before gas and spark are applied.
  4. joewein
    joewein Driving in Japan
    35
    17
    Tokyo, Japan
    2013 Prius Alpha
    The car is not going to work without a HV battery, but the primary effect of aging on the battery will be to reduce its overall capacity, not to kill it outright (it's not like a lead-acid battery where bits of lead crumble off the electrodes and eventually short the battery).
    As long as you have *some* capacity left, you will have no problems driving the car. All you'll see is a small to negligible drop in mileage, as less energy can be reclaimed during downhill stretches and red light stops, to be reused on the next uphill stretch or during acceleration. The car will still be able to start and stop the engine (no idling at red lights necessary) and run its on-board computer.
    Aging of the battery is much less of a problem than a lot of people imagine, since Toyota's hybrid system never fully charges or discharges the battery - it only uses a relatively modest capacity band in the middle of the theoretical discharge cycle. This helps extend its lifetime tremendously.
  5. bwilson4web
    15,508
    Removing the battery would have a similar effect to removing parts from an ordinary transmission to save weight. The car would be lighter but often incapable of effectively transferring engine power to the drive wheels. For example, reverse is only powered by the battery.
    The HV battery provides additional power for going up hills at high speeds, passing and taking off at lights. This allows a very efficient but less powerful engine to perform as if there were more power available. The HV battery provides 'surge' power that otherwise would require a larger, less efficient engine.
    The engine is started using the HV battery as there is no 12 VDC starter. It would require adding a starter motor and heavier 12 VDC battery just to get the engine running. Alternatively, you could use an external starter cart.
    As others have pointed out, the battery stores braking energy and returns it later. Think of it as a massive spring that slows the car when braking and then pushes the car forward later. This also means the brake shoes often last more than 100k miles. I'm at 118k miles and at this rate, my car won't need new pads until closer to 200k miles.
    So think of removing the HV battery as:
    • removing reverse gear - to save weight
    • a smaller engine - to save weight
    • removing starter motor and battery - to save weight
    • more frequent brake repairs - from saving weight
    Since the transaxle is computer controlled, the current software expects an HV battery and treats the absence as a fatal error. Removal of the HV battery requires replacement of the control computers and software. People bright enough to do that realize the weight savings are not worth the time it would take.
    Fleet as well as vehicle studies suggest the HV battery in my 2003 model, NHW11 could be reduced to about 1/3d Ahr capacity. My HV battery weights 50 kg (110 lbs.) The current model, NHW20, HV battery weights 45 kg (100 lbs.) But there are other ways to save weight.
    I suspect 100 lbs. could also be removed by stripping the air conditioner, heater, dash, radio and interior including the extra seats as well as the jack and the mini-tire used for a flat. There are racing techniques such as drilling lightening holes but this needs to be done carefully. Of course carbon fiber parts could be fabricated. Don't forget that the door latching mechanism and window motors are heavy. One could also also dress in lighter weight clothing, running shoes, remove body hair and the spare tire.
  6. patsparks
    10,664
    567
    Adelaide South Australia
    Can you remove the torque converter and clutches from an automatic SUV to save weight when they fail?
    No?
    Same with the battery in a Prius, however during the life of an SUV it is most likely you will need to replace these parts but with a Prius it is unlikely you will ever need to replace the battery. Problem solved because there is no problem.
    Enjoy your Prius and welcome to PriusChat.
  7. Patrick Wong
    18,200
    6,471
    As others have pointed out, the Toyota hybrid system is fully integrated and the system will not function if any part is not operational. So please do not expect that the system will operate in a degraded mode.
    However, the traction battery really is not a significant problem, because
    1) the warranty coverage is quite long,
    2) the failure rate is quite low, and
    3) there will likely be a large supply of batteries from salvage yards available at low prices. For example, 2G salvage batteries are currently available for around $400 plus shipping.
  8. Gen 3 for me
    Gen 3 for me Member
    198
    81
    Illinois
    Thanks for the great replies everyone. I thought when I read the below statement on several sites that it would be too good to be true for someone like me who likes to keep their cars for 20 years and can't justify the cost of an expensive HV battery replacement once out of warranty.
    quote:
    "Unlike most other hybrid vehicles available, Prius has been a "full" hybrid since introduction. This allows it to run on engine alone, battery alone, or a combination of both. The system blends the best of parallel hybrid and series hybrid designs" So I now see that I was over interpreting this statement to what I was hoping for.
    What I read in your replies encouraged me to not be as afraid of the HV battery life as I was before. Now I just have to run thru several economic senarios of what future gas prices might be, and my prospects of getting my old job back where I rode my bike to work for half the year, (2 mi daily round trip), vs my current 140 mi per day round trip to my new assignment.
    Keep up the good work.:)
  9. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Replacing the HV battery is similar in cost to replacing the automatic transmission on a normal car. The difference is that the HV battery will outlast the normal automatic.
    Tom
  10. dogfriend
    7,512
    1,185
    Carmichael, CA
    I'd rather swap out the HV battery than try to rebuild an automatic transmission. I think the car with the new (or salvage) battery would have a better chance of performing normally again.
  11. Patrick Wong
    18,200
    6,471
    Yes, the statement is true because during the course of your drive, you will find that the battery alone can power MG2 (motor generator #2) to move the car at low speeds and gentle acceleration. If you floor the accelerator, you will find that both the battery and the gasoline engine work together to provide maximum available power. Once you reach your desired cruising speed, you may find that either the gasoline engine or the battery (or both) supply sufficient power to maintain cruising speed, depending upon whether the terrain is flat, downhill, or uphill.
    However, the system requires all components to be functional at some point during your drive, as you now understand. BTW, others have asked this question, it is a very reasonable query.
    I believe that the Honda hybrid system for example, can limp along if the traction battery has failed. Good luck with your decision.
  12. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    main thing to understand is that your battery wont just quit - it will hold less charge, so your vehicle will be usable after 300,000 miles. And of course, used batteries are cheap - $400 from salvage yards (more Priuses are getting totalled than needing battery replace) - and since engine and other parts are worn less in hybrid vehicle, it will still be cheaper to maintain hybrid than petrol car even with mpg not considered.
  13. bwilson4web
    15,508
    The inverse question is also telling:
    Can 2010 run on HV battery alone when out of gas?
    The answer is yes for a limited distance, a mile or so. This can be the difference between reaching a gas station or a safe place to park versus being stuck in 'a bad place.'
  14. Patrick Wong
    18,200
    6,471
    To be precise, more 2G are being totalled than require a traction battery replacement outside warranty. No surprise since the warranty is 8 years/100K miles (or more), and the oldest 2G Prius are only 5 years old. We'll have to see how salvage battery prices change as 2G continues to age.
    Note that Classic salvage batteries are in much shorter supply and cost much more - this points to a higher failure rate as well as the older average age of the population, with more vehicles out of the 8 year/100K mile warranty period.
    Well, we'll see. I'd say that if a Prius transaxle fails and the owner can't find an independent to install a salvage part, s/he will pay around 3x more at a Toyota dealer, compared to an owner of a normal vehicle who will have a good number of aftermarket transmission repair sources available, assuming the owner has access to a reasonably-sized metropolitan area.
    However, use of salvage parts is a very reasonable alternative if the Prius owner can either DIY or find a cooperative independent tech willing to learn how to work on the Prius.
  15. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    This needs to be carefully caveated with "DOING SO MAY DAMAGE YOUR HV BATTERY". This would need done very slowly (as if in EV mode), and for < 1 mile. Any further and you may exhaust the HV battery to a state where only a dealer could recharge, or to a point where the battery pack must be replaced. There have been many threads outlining careless operation after running out of fuel.
    If you have an option of moving a short distance to be a safe place and walking to a gas station to buy a gas can and 1 gallon of gas, I'd strongly encourage this alternative.
    Better yet, make it a habit to refil at 2-3 pips at all times to prevent this situation in the first place.
  16. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    I doubt this will be true when it becomes an actual choice. I guess the transmission will be quite a bit more.
    OP: Google canadian Prius taxis. They are running on the original HV battery after 250k miles. And counting.
  17. Gen 3 for me
    Gen 3 for me Member
    198
    81
    Illinois
    Great discussion. Time will tell how the salvage market for Gen 2 & Gen 3 HV batteries will develop. I'm getting more comfortable that I can continue to use a Gen 3 with a less than optimum battery for some time after warranty ends which will come quickly for me mileage wise, not time wise.
    Thanks Patrick. I will check into this further also, to see if it can limp along for years on gas even though acceleration, braking, and fuel economy will suffer.
    I did work in a auto plant in mostly in chassis development for 17 years (not at Honda or Toyota) and have owned 5 Hondas (including CRX HF's and Civic CVCC's and loved them. Then I bought my first Toyota (2006 Sienna) and realized how superior Toyota is to Honda. So I really think the Gen 3 Prius is superior to the new Insight, not only in that the Prius has a much more advanced Hybrid system, and higher fuel economy, than the Insights, but also in terms of structural design and corrosion protection. But Hondas are still good cars and if the Insight would still work without the HV battery that might be the better choice for me based on how quickly I rack up the miles and how long I tend to keep a car. Its wonderful to have choices.
    The competition between Toyota and Honda is great for the consumer.:)
  18. richard schumacher
    7,663
    1,038
    United States
    If you are that worried about reliability and cost, buy a 2009 Prius. The Gen 2 battery design is more than five years old and pretty thoroughly debugged and proven in use. In contrast the first year of anything has bugs in it. You can get an excellent price now on a 2009.
    Also, unlike automatic transmissions, battery technology is improving rapidly. There is some hope that OEMs or the aftermarket will eventually offer replacement batteries that are better than the originals.
  19. HTMLSpinnr
    5,339
    917
    251
    The Gen 3 battery uses the exact same modules as the Gen 2. Only the cooling and maximum allowable draw changes.
  20. spwolf
    3,156
    440
    Eastern Europe
    as to the battery tech, let me put this :).
    I have to see it yet, and I have been listening about it for 5-6 years now, some of you even more. I dont think startups can compete in this field.
    Especially since you can buy used battery for so cheap, who wants brad new one for 6x more?
