Can a 2019 LE AWD-e take a spare tire?
Discussion in 'Gen 4 Prius Main Forum' started by Edison, Apr 29, 2019.
  1. Edison
    Edison Junior Member
    36
    Belgrade, Maine
    2024 Prius Prime
    SE
    When the salesman (who had been trained on the AWD-e) and I looked in the back and tried to pull up the foam plastic insert, it was held down with a button clip attached at the bottom. Based on its shape, no telling what was below and whether the electric drive intruded into the spare-tire space available on the regular LE. Does anyone know whether a compact spare can be fitted?
  2. Mendel Leisk
    41,889
    I've got a strong hunch no, it's not physically possible, due to rear wheel drive components in the way.
    knockknock_2 likes this.
  3. Edison
    36
    Belgrade, Maine
    2024 Prius Prime
    SE
    Well, we have a 2016 RAV4 hybrid with the same electric drive rear axle as the AWD-e Prius, and there is plenty of room for a spare tire and associated stuff with it, so I'm not convinced by your logic. In any case, I'm hoping to find someone with actual experience.
  4. Usle
    Usle Active Member
    317
    140
    Me
    2018 Prius Prime
    This page says the le has the 1/2 spare, tried to build it no 4 wheel drive came up to see if the all wheel drive does also, but.....the electric drive Is on the axles.
    The 4 seat prime doesn't have the spare, the 2020 prime goes five seat.
    2019 Toyota Prius Tire Specs
  5. Mendel Leisk
    41,889
    I suspect your hopes will be dashed, lol.
    I've seen a cut-away view illustrating the rear-wheel drive on the Prius AWD, and the mechanism looks to be more-or-less right in the middle of where the spare would go. Tried looking for it right now, without luck.
    Addendum:
    Here's another Priuschat thread on the subject, saying no spare and maybe no hope of shoe horning one in:
    Prius AWD-e - Rear Drive Layout and Spare Tire | PriusChat
    OTOH, this site makes mention of E-four, with temp spare:
    Toyota details powertrain advances in Gen4 Prius; available E-Four system for all-wheel drive (not for US) - Green Car Congress
    Screen grab from above:
    Addendum #2: the above link was published in late 2015, and that could well be a typo, the bit about E-Four with spare.
    FWIW, in Canada for 2019, there's 4 Prius models, paraphrasing a bit:
    Prius
    Prius Tech
    Prius AWD
    Prius AWD Tech
    Only the bare "Prius" has a spare. I'd suspect the "Prius Tech" could also, if you threw over a grand at it.
    #5 Mendel Leisk, Apr 30, 2019
  6. Edison
    36
    Belgrade, Maine
    2024 Prius Prime
    SE
    Yes, my reading of that last link, from which Mendel Leisk took the screen grab, is that Toyota actually installs a spare tire in the AWD-e vehicle sold in non-US markets.
  7. Mendel Leisk
    41,889
    Sadly I'm not so sure, see my addendum 2, just added above.
    Our local dealerships are awash in Prius AWD, Prius Prime, the occasional Prius Tech. None with spares. Between that and the styling (inside and out), I'm waiting this gen out. Maybe forget about it completely, if the next gen is similar.
  8. Awap
    Awap Member
    48
    28
    Boulder, CO
    2019 Prius
    LE AWD-e
    What's wrong with just putting a spare in the cargo area (edit: I mean, just lying on the floor)? There must be some way to tie it down?
    #8 Awap, Apr 30, 2019
  9. thomassster
    thomassster Member
    239
    83
    Colorado, US
    2019 Prius
    XLE AWD-e
    I looked in my new 2019 awde xle and lifted up the foam. Confirmed that the awd battery takes up the spot in the dead center. So can’t add a spare.
    Ms. Molecular Motors likes this.
  10. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    I don't think that's a battery - it's under the back seat - more likely the motor. But - we don't get them here, so I can't check.
  11. thomassster
    thomassster Member
    239
    83
    Colorado, US
    2019 Prius
    XLE AWD-e
    I got terminology wrong. I saw orange wires so thought battery. Here are the pictures.
    alanclarkeau and Mendel Leisk like this.
  12. Mendel Leisk
    41,889
    The beleaguered spare tire get's the bum's rush every time they come up with something newfangled. :(
    alanclarkeau likes this.
  13. alanclarkeau
    7,045
    7,593
    What I don't understand - cars got lower and sleeker about 15+/- yrs ago, and they started putting in sleek spare tyres to match - blaming the styling. Then along came the SUV with no excuse because it's jacked up in the air - and they've still got the half hearted spare - or NONE. Maybe it's about time for us to revolt (or be revolting)?
  14. Mendel Leisk
    41,889
    I look at that picture of the inverter plunked in the cavernous spare tire well, and all I can think is "dog in the manger".
    That's not the most eloquent engineering effort...
    kithmo and alanclarkeau like this.
  15. Vman455
    Vman455 Senior Member
    539
    556
    The Middle
    If it's any comfort, you both got the terminology wrong; that's the rear inverter. Interesting to see that the AWD has an entirely different rear pan than the FWD. It's different under the car too, where the AWD has a smaller muffler (painted black for some reason), and is missing some of the plastic fairings on the FWD at the back.
    krmcg likes this.
  16. alanclarkeau
    7,045
    7,593
    Yes, of course - but when I replied, he hadn't posted photos - I just knew it wasn't a battery. We don't have AWD cars available here.
  17. KDay
    KDay New Member
    Missouri
    2019 Prius
    How did you lift up the foam? I have a 2019 Eco and can't figure out how to do so.
  18. thomassster
    thomassster Member
    239
    83
    Colorado, US
    2019 Prius
    XLE AWD-e
    I have the 3 foam configuration.l so the 2 foam configuration might or might be different. There are black clips you use a small flat screw driver to pop up. The others, you have to use force to pop up by lifting the foam.
  19. JimBobWay
    JimBobWay Junior Member
    2021 Prius
    XLE AWD-e
    Amazing Photos. The Spare Tire hold down weldment, is right there, and Toyota bolted an inverter to it.
  20. JimBobWay
    2021 Prius
    XLE AWD-e
    Good Tech could solve this issue. Think of a custom, unusually thin, spare wheel made of light weight alloy. It could have a fairly narrow, low profile, temporary spare tire mounted to it. Save more space by compressing the tire, un-inflated with a removable plastic sleeve. Include a compressed gas canister to inflate it, or a small 12V air pump. Toyota has great designers, they could work out the details, even if they had to install a "Temp. Spare Sensor" that limited the Prius top end to 55 MPH.
