Can an Overfilled Master Cylinder Result in Damage?
Discussion in 'Gen 2 Prius Technical Discussion' started by Priusyipee, Aug 7, 2014.
  1. Priusyipee
    Priusyipee Active Member
    350
    269
    Upstate New York
    Long Story short: Brakes replaced at local dealer (courtesy offer from Toyota Corporate). I paid dealer, submitted invoice and received reimbursement. Service tech replaced front pads and rotors. Everything seemed fine until the day I popped the hood to detail the engine. Noticed that the fluid level in the master cylinder was at the cap and the cap itself had "popped" due to the excess pressure in the system. Brought the car back to the dealer. I was reassured that after draining off the excess fluid, the braking system would be OK. I disagreed. Thoughts/Opinions on this?
  2. Patrick Wong
    18,200
    6,472
    This is indicative of sloppy work on the part of the mechanic, but you should not have to worry about braking system damage. If the brake fluid got on painted surfaces it will do damage to the paint.
    Priusyipee likes this.
  3. Mike500
    Mike500 Senior Member
    2,593
    764
    There should be no damage to the braking system.
  4. Priusyipee
    350
    269
    Upstate New York
    I insisted that the dealership flush the system as I was worried that the cap, having popped open due to the excessive pressure allowed the fluid within the system to be exposed to air and thus, moisture. Since the dealership (and I) know that it will take a while to get the job done, they have made an appointment for me to bring the car back.
    Meanwhile, the fluid level was readjusted. I could have done that myself but I wanted the service manager to see the "quality" of work that was coming out of their shop. I was shocked that the mechanic did not remove the cap before compressing the caliper. Result? There will be a "meeting" between the employees and the service manager to discuss this event. Hope it helps.
  5. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    Good job of having the service manager see the quality of work. They cannot make improvements if they do not get good feedback. A phone call is better than nothing but taking the car back to them to see in person works best.
  6. Patrick Wong
    18,200
    6,472
    Yes, the mechanic is supposed to look at the brake fluid reservoir prior to working on the car, and suck out some of the fluid using a squeeze bulb if it is apparent that the current fluid level is already near full. This is standard procedure when working on any disc-brake equipped vehicle, prior to removing the calipers and compressing the pistons back in.
  7. Priusyipee
    350
    269
    Upstate New York
    ...Exactly what I told the service manager. I believe that the mechanics are under such pressure to get the job done as fast as possible that they get careless... although I can not understand how or why an experienced mechanic could or would fail to do this. It is my impression that the hood remained closed and that the brake fluid reservoir was neither checked before or after the job was completed.
  8. Patrick Wong
    18,200
    6,472
    You may be right, and if so that would be a big lapse on the part of the mechanic.
