Can anyone explain multi-frame CANbus resonses?
Discussion in 'Gen 2 Prius Technical Discussion' started by Dan., Sep 1, 2009.
  1. Dan.
    Dan. MPG Centurion
    387
    127
    Houston, Texas
    I'm trying to understand multi-frame CAN responses. I understand that a length of 0x10 indicates that there is a multi frame response, but I don't know what the format of the other frames should look like. For example
    If I send: 07E221C3
    I get back: 07EA102761C3400111D00000
    OK... but what is the key field I need to look for to piece grab the other response frames.
    I see multi-frame messaging mentioned here, and I looked through the Bosh spec on CANa and CANb and see no mention of multi-frame messaging or response fragmentation.
    11011011
