Can anyone, please provide me with the info for these two pieces of plastic cover?
Discussion in 'Prime Technical Discussion' started by greenquark, Apr 29, 2025.
  1. greenquark
    greenquark Junior Member
    montreal
    2020 Prius Prime
    If I want to replace them. Do I need to replace the whole grill?
    Thank you in advance
  2. Mendel Leisk
    40,457
    If I recall correctly, you may have to. @jerrymildred tried disassembling the front bumper, kinda hit a wall, some of that stuff heat-welded.
    I used to refer to it as the "chandelier bumper"...
    Addendum:
    Some info:
    Front Bumper: Acrylic Crack Protection | PriusChat
    #2 Mendel Leisk, Apr 29, 2025
  3. greenquark
    montreal
    2020 Prius Prime
    Thank you for the info. It looks like the plastic dip is a good solution. I never hit anything, so I am guessing someone hit me backing up from parking. It was during the winter, too. Maybe the Temperature swings make that acrylic more prone to cracking.
    I am thinking of buffing a bit of the acrylic and gluing the cracks before applying the plastic dip. I think if applying the plastic dip directly , the cracks might break the plastic dip due to friction/motion between the surfaces. Am I correct?
    "chandelier bumper" is a very good fit for this. What a design flaw for such a well-thought-out car!
    Cheers!
