Tags:
  1. JSomms
    JSomms New Member
    Yesterday
    Ft Lauderdale
    Hi everyone! I’m new here but owned my Gen 3 Prius for 10 years. I have 209k miles on it and the death rattle started and some white smoke out the tail pipe. I did a quick YouTube check and egr and cooler needs a good cleaning. I followed the steps from Merv and cleaned my egr pipe and cooler. Put everything back and the white smoke is gone but still have the death rattle when car is cold. Can the egr valve be bad? If anyone can help, thanks
    Jerry
  2. Mendel Leisk
    40,797
    Likely head gasket has failed, is leaking coolant into cylinders, and the “death rattle” is due to engine’s struggles to compress the coolant.
    that was the first EGR cleaning?
  3. Brian1954
    Brian1954 Senior Member
    1,904
    752
    South Central PA, USA
    I agree that the likely problem is that the head gasket is starting to fail.
    In the early stage of the leaking head gasket in the Gen 3 engine, the "death rattle" is due to misfires caused by the leakage of coolant into the cylinders. The coolant cause the spark plug to create a weak or no spark from the plug until the coolant is forced out through the exhaust valve of the cylinder. Then, the spark plug will work properly, and the misfire will stop occurring, and the engine will run smoothly again.
    In the advanced stage of a leaking head gasket, you could get enough coolant into the cylinder for the engine to struggle to compress the coolant in the cylinder. Once that occurs, you will bend or break the cylinder rod. If that occurs, it is time for an engine replacement.
    #3 Brian1954, Aug 25, 2025 at 9:10 AM
  4. ChapmanF
    17,600
    There's probably a continuum involved, where enough coolant can collect to effectively raise the compression ratio and make the compression stroke harder to complete, but before it gets so hard as to break something.
    But it's worth remembering that none of that is necessary to make the awful rattle. It is a big noise, but does not need a big explanation, and even simple misfires in a Prius cause that noise. This classic story concerns a Prius that was let go for scrap price when the awful rattle came from misfiring caused by a single spark plug, and there was a quite recent thread here where someone seriously considered letting the car go for scrap price and the cause of misfiring was an injector.
    The engine is connected by fixed gearing to two massive motors (and one of the massive motors is further connected by fixed gearing to the whole mass of the car). Misfiring makes the rotational speed of the engine uneven, and the car isn't able to control the motor rotation precisely enough to match those variations, and there is always some lash in the gearing that can clunk back and forth. There's a torque damper between engine and transmission to make the clunks a little less bad, but that takes its toll on the damper too.
    That's not to say your trouble is a spark plug or injector. If there was white smoke, head gasket sounds like a good call. The point is just that the misfiring caused by coolant's presence in the cylinder is already quite enough to explain the awful noise.
