Can Faulty Low Pressure Indicator Cause MPG loss?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by priifamily, Jan 24, 2012.
  1. priifamily
    priifamily Junior Member
    banning, ca
    My 07 with 178K miles is getting about 35MPG and the only thing noticeably different in the constant lighting of the low pressure indicator, even tho the tires are fine.
    Stopping by Costco Tire, the mgr. said there is a battery in the indicator that does wear out, knowing how linked the electronics are in these cars, could this be the cause of the poor mileage?
    Can this part be purchased aftermarket and installed by a DIY-er.
    Thanks for any help.
    TD
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    A failed TPMS sensor will not change your mileage or cause any other weirdness with electronics. It will, however, mask an actual drop in tire pressure, which will hurt mileage and compromise safety.
    Tom
  4. priifamily
    banning, ca
    thx Cwerdna , i will do that asap. We own a 10 and an 07 if that helps.
    thx Qbee42 I'll check it out. right now nursing daughter who just had four wisdom teeth pulled, hope she is still smarter than her old Dad.
  5. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    Does the 2007 still have the original 12V battery? A failing 12v battery has been known to cause the ICE to not shut down since it's trying to charge the battery. Does the ICE (gas motor) seem to be running all the time?
