Can I buy turn signal wire harness from somewhere?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by yibo829, Aug 23, 2014.
  1. yibo829
    yibo829 Junior Member
    84
    In the past I did the turn signal DRL modification. Which involved me cutting the turn signal wire. Now the module broke and I want to do a reverse install. But the wire at the turn signal socket is now too short to be able to work with.
    So I want to buy a replacement.
  2. exstudent
    exstudent Senior Member
    2,214
    901
    Torrance, CA
    I guess splicing wires into the harness for the correct length would be too difficult?
    Contact Steve Woodruff. He should be able to get what you want.
    Internet search for "Prius junkyard," lists junkyards and companies that sell used parts. I'm sure one of these would be another option.
    Good luck.
