Can I charge the 12 v with a conventional battery charger?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by a4retome, Feb 11, 2009.
  1. a4retome
    a4retome Junior Member
    22
    Northern CA
    Proud owner of a 2005 Prius with all the extras. Since my wife and I live and teach overseas, the car has been put into storage and my mother-in-law starts it and lets it run for about thirty minutes every two weeks, mostly to make sure the 12 v in the trunk stays charged. We've worked this routine for over a year, with no problems and last summer we took the car out for 6 weeks during summer break and the car ran great.
    In the last several weeks however, when she goes to start it, she's discovering a dead car unable to start, or the dash lights come on very dimly and sometimes it starts. AAA has come out a couple of times already.
    My calls to two Toyota dealers gave conflicting answers. One says "Bring her in for service...the battery needs replacing." The other dealer said, "The battery should be fine on that 2005.... since it only trickle charges when the car is running, just let her run for 4-5 hours ever two weeks and pull the dome fuse under the hood to disable the wireless system and the radio memories, etc." I'm not keen on either idea due to the expense and the environment and neither dealer could answer the real question I had:
    Can I hook up a conventional plug-in-to-the-outlet battery charger and let it charge overnight? If I can, and the 12 v continues not to hold a charge, we'll obviously replace it. Kind of surprising given only 38,000 miles and 4 years.
    Any other thoughts are welcome too. If the battery does need replacing, is this one any good? 12 Volt (12v) Toyota Prius Auxilary Battery for 2004, 2005, 2006, 2007, 2008 and 2009 with installation kit and free shipping
    Thanks in advance!
    Chris
    El Salvador
  2. kenmce
    kenmce High Voltage Member
    1,528
    504
    NY
    It's just like any other small 12 volt lead/acid battery. A charger will work fine on it, although you have to kind of dig down in the trunk to get at it. Be careful not to get the terminals connected backwards, you'll break things if you do.
    Roughly the same age/miles where I replaced mine.
    I got that one, was a pain to install but works good so far.
    If he's refering to the smart key system, there's a small button on the dash under the steering wheel that will turn off the SKS.
  3. a4retome
    22
    Northern CA
    Thanks for the help. I'll try charging it and if she doesn't hold, give the replacement a try. Cheers!
  4. kenmce
    1,528
    504
    NY
    Give yourself plenty of time if you put in one of the yellow top batteries.
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    You don't have to dig in the trunk to charge the battery. There are jump points under the hood for that purpose.
    Tom
  6. TheAnnoyingOne
    TheAnnoyingOne New Member
    318
    -118.15476, 34.112134
    Do you have a key less entry option? - If yes it helps if you disable it by pressing the left button that is located bellow the steering wheel,.
    (There are two buttons there, the right one is for resetting the Tire Pressure sensors and the left controls the key less entry)
    Once you do that the system will not add drain to the 12 v trying every few seconds to locate a nearby fob.
  7. richard schumacher
    7,663
    1,038
    United States
    Do you have a voltmeter? With the car OFF measure the voltage at the jump points. It should be 12.6V to 12.8V. If it's less than 12.0 V it's definitely time for a replacement. If you don't have a voltmeter use the self-test procedure given in this thread:
    PriusOnline.com • View topic - how to put 12V battery in sleeping mode?
    If you install the Optima using the eLearnaid kit note that it is very helpful to use pliers to put a bend into the lug on the negative cable so that it will fit flush against the mounting surface in the car. Otherwise it will try to pull the mounting stud out of the car wall as you tighten the nut (all this will become clear when you have the kit in your hands).
  8. Patrick Wong
    18,200
    6,472
    Note that TSB PG007-03 specifically recommends against using a regular 12V battery charger, so this is at your risk. Also note that the TSB sugggests charging the battery when it is disconnected and out of the car. I think the reasoning for this is two-fold: in case the battery explodes while being charged, it will not damage the car, and the charging current has no opportunity to damage the vehicle's electronics.
    I see no problem using a regular charger, as long as you set the current switch to the low current position, such as 2A. Note the warning label on the battery top that says 4A is the maximum charging current.
    You've got a reasonable maintenance routine, with the car being made READY for 30 min. every two weeks. However it doesn't surprise me that your battery died after four years, since it is not being used much.
    Note that if you move to the Optima you'll have to install a new positive battery terminal connector on the fuse block, and use a new negative battery cable, since the Prius original equipment battery uses smaller than normal terminals.
    I see that the Optima price is $180 incl shipping; depending upon how much parts are marked up at your local Toyota dealer's parts counter, you may find that you can buy the replacement for less there, perhaps $130 - $160 or so.
  9. a4retome
    22
    Northern CA
    Thank you everybody for your thoughts and advice for my situation! I'm in a bit of a bind since I am living in Central America and have to trust my mother-in-law (shudder) to take care of our Prius in California. If I were there, or could get a cheap weekend flight home, I would change out the battery myself either with a dealer model or the Optima version.
    What are your thoughts about the longevity of the Yellow Top Optima batteries? Are there any Prius Chat reviews of this battery? The on-line reviews I can find speak very highly of it OR very poorly of it, but maybe they were reviewing yellow tops for regular cars and boats.
    Finally, if I elect to have the dealer replace the battery, any idea what the cost will be battery and labor.
    Gracias everyone!
    Chris
    El Salvador
  10. Patrick Wong
    18,200
    6,472
    Hi Chris,
    I don't think that anyone has owned the Optima long enough to say for sure that it is really better than the original equipment GS battery. In theory it has better specs, but who knows.
    It sounds like your normal schedule would have you return to CA only during the summer. If true, then my suggestion is that you leave the car alone for now with its dead 12V battery, and worry about replacing it when you come back in June or whenever. Your mother-in-law will be happy that she doesn't have to start the car periodically, in the interim.
    The only problem will be that the traction battery may lose some charge over the next four months. However, if the last time that the car was run the SOC gauge was in the blue region, then I think it should be OK.
    If you will continue to live in El Salvador indefinitely, then I suggest you consider one of the following alternatives:
    1. Sell the Prius so you and your MIL don't have to worry about it.
    2. Charge up the traction battery to green bars by using the force-charge method, and make sure the 12V battery is also fully charged. Then disconnect the 12V battery and leave the car alone until you return the following summer.
    3. If you are storing the car in covered parking and have access to a 120VAC outlet, then invest in a battery tender to keep a trickle charge on the 12V battery, and have your MIL start the car once a month, leaving the car READY for an hour or so, for the sake of keeping the traction battery charged up.
    The force-charge method is to shift into D, hold the car stationary by pressing the brake pedal with your left foot, then floor the accelerator pedal with your right foot. Since the car cannot move, the ICE will spin MG1 and the energy from MG1 will be directed into the traction battery. Use of this technique is at your risk as the transaxle is stressed during this process. You'll note that the engine RPM will decrease as the traction battery SOC increases.
    On a different subject, I hope that you are changing the engine oil and oil filter annually even if you are not driving the car much, to avoid engine sludge buildup.
  11. a4retome
    22
    Northern CA
    Great advice all around. Thank you.
    I'm a little reluctant to let the car set without running it for 4 months until we get home in June. She does have Mobil 1 in her which I changed just before we left last July. Yes, for the foreseeable next couple of years, we will be away for most of the year (next stop Bangladesh!) and return for summer break for 6 weeks in June.
    We have considered selling the car since we really only need it for 6 weeks out of the year. But that being said, the car is paid for and my wife and I love it. Love to drive it, love that we can make a small difference with the environment, love that we can support a car company that is riving the green car revolution.
    So lots to think about. Thanks again!
    Cheers!
  12. qbee42
    18,058
    3,074
    Northern Michigan
    I would prefer to see it driven every couple of weeks.
    Tom
  13. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    The Prius 12 vdc battery isn't known for outstanding long life or durability. Remember that unless special modifications are made to the Prius, you cannot use one of those chargers that plug into the "cigarette lighter" plug under the dash
    I'm frequently away on business, and also had trouble the first winter with my Prius. You can blame -40 temps, constant use of electric rear defrost, and headlights always on in our dark winters, for that
    I finally put in a VDC Battery Minder, and that solved all my battery problems. I use the Battery Minder on all my equipment now
    BatteryMINDer® Plus 12 Volt 1.33 Amp Charger-Maintainer-Conditioner (Desulfator) :: All :: Battery Chargers by BatteryMINDers.com
    I didn't catch where the car is parked, or if it's parked inside a garage. If it's a moderate climate, no extremely cold temps, especially parked outside, I really wouldn't worry about the car not being run.
    There are plenty of classic and collectible cars that stay parked 5-8 months of the year, with no motor damage. Of course, heated dry indoor parking helps there.
    The nice thing about the Prius gas tank bladder system, is that you shouldn't have moisture condensing inside the tank
  14. richard schumacher
    7,663
    1,038
    United States
    It would be a lot cheaper to rent a car for six weeks each year than to buy one, no? The Prius environmental benefit is going to waste sitting in a garage 48 weeks of the year.
