Can I drive like this
Discussion in 'Prime Main Forum (2017-2022)' started by JeffreyLebowski, Mar 23, 2022.
  1. JeffreyLebowski
    JeffreyLebowski New Member
    Queens
    97848599-E966-425C-938B-076AD26A8B8B.jpeg E28BD054-22FD-421F-9FE0-C915FD0A5268.jpeg BA170A90-6878-4F6B-9B7D-46DD4E01394B.jpeg Overshot my turn into my extremely tiny driveway and ripped the “bumper”/fog light cover on a flower box. Very bummed. .
    can I drive like this?
    should I get it fixed immediately?
  2. Salamander_King
    Salamander_King Senior Member
    10,975
    8,873
    New England
    Whoops. If the turn signal still works, I guess you could drive. But if it was mine, I would be fixing it as quickly as possible. That's what the insurance is for.
    schja01 and jerrymildred like this.
  3. BiomedO1
    BiomedO1 Senior Member
    1,535
    823
    SacTown, Ca
    Rotate that signal lamp back into place and that should close-up the gap. Clean the area with gasoline or other non-oily cleaner; something that will strip-off the wax. Use silver duct tape of gorilla tape to cover it up. Give the area a tug; to make sure it won't separate when your on the highway. That should hold up for a while, until you can get it fixed.
    The entire bumper assembly will need to be replaced. Hopefully the body shop will be able to salvage your marker lamps and other nick-nacks, to keep cost down.
  4. citiprius
    citiprius Active Member
    241
    237
    51
    2018 Prius Prime
    I will use glue gun with addition plastic plate (slight curve to match the contour) to connect them from inside. First remove the screws (6 or 7 of them) from the bottom of the bumper, then remove long triangle plastic cap next to the turn signal light module, then remove the light module (3 screws I think) through the bottom, then glue it from inside, once secure, then put back the light module and everything else.
  5. BiomedO1
    1,535
    823
    SacTown, Ca
    Well; If he's mechanically inclined enough to remove the front bumper cover. He can simply epoxy the back side and perhaps find a piece of plastic backing for added strength. Then later get the crack filled and bumper repainted.
    Looks like around $155 @ rockauto w/o parking sensor option. You'll still need to get it repainted to match the car.
