Can I have normal tires, not low profile tires?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by SoShoreKen, Apr 12, 2021.
  1. SoShoreKen
    SoShoreKen Junior Member
    South Shore MA
    My tire pressure light came on, again. I've had to replace or patch a bunch of tires since I bought my Prius. I've had more tire issues with this car than all the other vehicles I have owned in my entire life combined.
    It says the tires are low profile. Can I use normal tires?
  2. Salamander_King
    Salamander_King Senior Member
    11,019
    8,953
    New England
    What size of wheels and tires do you have? If it is a 17" wheel, then it has to be a lower-profile tire than OEM 15" tires 195/65R15 to be able to fit. If you want a higher sidewall, your option would be to change to 15" wheels.
  3. Mendel Leisk
    41,448
    Ours came with 215/45R17, and every winter I swap over to 195/65R15 snow tires (on Corolla steel rims), no problems.
  4. SoShoreKen
    South Shore MA
    Its a Prius Persona model. 17 inch tires. How come tire pressure is such a big issue with this car?
  5. sLick415
    sLick415 Member
    214
    55
    San Francisco, CA
    I'd stick with the recommended size. You'd have clearance issues with the wheel well if you went with a bigger tire.
    The issue isn't the car... What's the tread life on your tires? How are you patching them? Is or was there road work on the routes you typically take?
  6. Jim Swart
    Jim Swart Member
    57
    Portland, OR
    Original equipment size is 215/45R17. There is plenty of room for 225/45R17.
  7. bisco
    51,929
    maybe go with the standard 15". i'm on my second set at 74k. no issues with pressure, i load 'em up so it takes months for them to fall below the tpms threshold. years even.
  8. SoShoreKen
    South Shore MA
    Since I took delivery of my Prius, tires has had to gotten patched, or replaced. Tire pressure lights keep going on. Sick of it. I'm a smart guy, I know how to look at a tire and read a tire gage to see if I need to put air in my tires. I don't need a tire pressure light coming on every 3 days saying I have to put air in my tire saying I'm a screw up.
    I've had the same job for 17 years, drive the same route too and from work every day. I've had like 4 cars since I started working there. This Prius is the ONLY car where the tire pressure light keeps coming on. Checked sensors, ect. Sometimes it stays off for a few months, but it always comes back. I want them off, deactivated. Or set to go off when they are at 1 PSI. Sick and tired of this happening all the time, what's the fix besides getting a new car? I don't want them to come on, ever. I feel its telling me I'm screwing up. When I get it fixed they tell me its all set, then it comes back on after.
    I've been driving for almost 40 years. This is the only car that has given me this much trouble with tires. So I know its not me.
  9. SoShoreKen
    South Shore MA
    I assume if I go with the 15 inch tires, I have to get 15 inch rims? So that's more money to fix it.
  10. bisco
    51,929
    correct, some people put a piece of electrical tape over the light.
  11. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    low profile tires have little to no shock absorbance. The impact of pit holes goes straight to the rims and the rims rips through the tires since there’s a lack air between rims & tires. Low profile tires look great on the car, bad in the wallet.
  12. Mendel Leisk
    41,448
    @Grit some good material here.
  13. alteea
    alteea New Member
    United States
    2014 Prius c
    Most aluminum wheels leak after a while. Corrosion. Remove tires and put sealer on the bead area.
    SteveSco likes this.
  14. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    There's a TPMS button deep under the driver side dash. Everytime you adjust the pressure, you're supposed to reset it. Then it won't come on until a drop of 20 - 25 %, a significant amount. Put lower pressure in, reset it, then pump them back up. Shouldn't come on unless you're really flat. Probably was reset with too much pressure in the tires.
    moto g(7) power ?
    jerrymildred and Jim Swart like this.
  15. bisco
    51,929
    should be able to find salvage 15 rims for cheap
  16. fuzzy1
    10,451
    I very strongly suspect that car #1 didn't even have tire pressure lights, because it pre-dated the TPMS mandate, which started phasing in 15 and a half years ago.
    Which of those other cars had TPMS? Any of them?
    You haven't said whether these pressure warning are mostly valid (tire or wheel problem), or spurious (car problem). So we can't really tell if you are yanking our chain, or ...
  17. SoShoreKen
    South Shore MA
    Good to know. I'll go that route. Be cheaper in long run.
  18. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    Finally! I was reading along wondering if anyone would think of this. In fact, @SoShoreKen, you should be able to practically eliminate the TPMS safety measures if you lower the tire pressure to some silly-low pressure, then hit the TMPS button, and then pump the tires back up.
    However, to blame the car for tire punctures is just silly. :LOL:
    jzchen and Jim Swart like this.
