Can I improve my 2009 ac myself???
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by MattyD., Aug 12, 2021.
  1. MattyD.
    MattyD. Junior Member
    43
    Oregon coast
    Hey all, iv done a bunch of searches and it looks like a lot of ppl are saying in general, you should take your prius to a dealer for any kind of air conditioning related work. I have a 2009 with 190k and the ac works decent. After driving my sisters 2004 accord with ac cold enough to freeze off the twig and berries, id like to see if I can improve the ac in the prius. I purchased a basic can of recharge stuff from O'Reillys but read on the can that its not for use with hybrid vehicles. So my question is, can I use a basic recharge system from the parts store and just top of the coolant level like a normal car, or do I need to have a professional do it. Obviously I'd rather use the $40 parts store method then spend $150-500 for a dealer/ professional to look at it, iv heard all to many dealer horror stories.
    Thanks!!
  2. ChapmanF
    17,343
    Refrigerant can be sold pure, or with various additives in it, like oil, with the idea of replacing some of the original oil that you think might have leaked out with the old refrigerant.
    You can add absolutely pure refrigerant, or you can add refrigerant with oil if the oil is guaranteed safe for a hybrid's electric compressor.
    If you add refrigerant with oil made for "a normal car", or even if you use hoses that have touched such oil, it will immediately begin degrading the insulation in the electric compressor. As soon as that insulation shorts across, your car's A/C will be done.
    Refrigerant in an air conditioner doesn't have a 'level' to 'top off' to like engine 'coolant'. It is there in the system in both liquid and vapor form all the time. When the system is off, with anywhere even near the right amount, its pressure just tells you what the temperature is, not how much refrigerant is inside. When the system is on, the pressure behavior is complicated.
    The refrigerant is best measured into the system by weight, but you don't know how much is left in there, so that should be safely recovered first, and then the proper amount put in by weight. That's the way a decent shop will do it (whether a dealer or any good independent car A/C shop).
    @lech auto air conditionin can explain more about the likely results of the $40 parts store method.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    Don’t know where your reading take it to the dealer but that’s the last place to take it at $180 an hour.
    Prius is a very common car ac shops know about it.
    Do not use the can you bought. G2 ac when working properly is freezing
    If yours is not it has a slow leak. Take it to a good shop they will charge it up with dye and find the leak. Dont be surprised if it’s the ecoil under the dash very common on this car. They charge $150 by me for a charge and dye.
    Just had my ecoil replaced on my 07 it is freaking freezing. Have to run it at 70 or it’s uncomfortable.
  4. MattyD.
    43
    Oregon coast
    Thank you very much for the reply, is there a way to self diagnose the Ecoil?
    edthefox5 likes this.
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    You have a normal 12 year old car. No automotive AC system is perfectly sealed and all will experience some amount of refrigerant leakage. A perfect seal will be invented right after a perpetual motion machine. Your statement (above) says it all. Normal degradation. Most likely all it needs is a 'tune up', not component replacement.
  6. MattyD.
    43
    Oregon coast
    Ok so I need to take it to an ac shop for servicing, if it wasn't for the fact that oregon is turning into Arizona, it wouldn't be a problem. We have broken our heat records 4 or 5 years in a row now (up to 116 so far this year) so top notch ac is essential.
  7. Another
    Another Senior Member
    1,818
    515
    Naples, Florida
  8. ChapmanF
    17,343
    Even more interesting to take the 45 "All Time Record High" dates from that map you linked, and put them in order.
    Code:
    1898-08-10
    1905-07-08
    1905-08-07
    1922-07-02
    1925-06-24
    1928-07-23
    1928-07-24
    1939-08-23
    1946-07-20
    1946-07-20
    1946-07-20
    1955-09-04
    1961-07-11
    1961-07-11
    1961-08-04
    1961-08-04
    1961-08-05
    1977-08-18
    1977-08-18
    1979-09-14
    1981-08-10
    1981-08-10
    1981-09-06
    1990-07-12
    1994-09-22
    1998-08-05
    2002-07-11
    2002-07-12
    2002-07-12
    2002-07-13
    2002-07-13
    2003-07-23
    2003-07-24
    2009-07-29
    2014-07-17
    2018-08-10
    2021-06-27
    2021-06-28
    2021-06-28
    2021-06-28
    2021-06-28
    2021-06-29
    2021-06-29
    2021-06-30
    2021-06-30
    19 of them were set in the last 20 years, and 9 of those were set this year so far.
    Maybe there's something going on besides Oregonians becoming wimps.
  9. edthefox5
    10,096
    4,831
    Clearwater, Florida
    You can turn on the ac and look in the sight glass. It will probably look like condensation/ bubbles flowing fast through the glass which is not good.
    Stop using the ac low charge is very hard on the compressor.
    Like TMR says slow leak over years happens may be loose coupling or an easy fix. Mine leaked so slowly over years you hardly notice the decay in
    Performance until it’s clearly not cooling well.
    A proper working G2 ac system will freeze you out.
    only way to tell is professional investigation. $150.
  10. lech auto air conditionin
    830
    601
    261
    san francisco
    Some people get it right and some people do not.
    your Prius should get this cold.
    #9 lech auto air conditionin, Aug 14, 2021
