Can I Leave My HEV In Ready Mode With Doors Locked?
Discussion in 'Gen 5 Prius Main Forum' started by VelvetFoot, Apr 20, 2026.
  1. VelvetFoot
    VelvetFoot Senior Member
    1,388
    538
    New York State
    2026 Prius
    Assuming the starting SOC of the traction battery is high and the car is outside with heat/AC off.
    Manual seems to have no prohibitions on it, other than the exhaust fume thing.
    I'm assuming the engine would start at SOC of 33% or so.
    The traction battery would make a very large dashcam battery. :)
    edit: Have to use the metal key and possibly turn off the auto power off feature to lock door and keep energized.
    Also, the gauge cluster is lit up, drawing attention.
    The three-press trick on the door lock button on remote turns on the hvac system to auto, and probably only runs for a certain amount of time to warm/cool the car.
    #1 VelvetFoot, Apr 20, 2026
  2. ChapmanF
    18,861
    I don't know about any gen 5 details that might be different, but yes, through gen 3 you certainly can, if you use the metal key to lock.
    And yes, the dash lights will attract attention, and the engine will start and stop, attracting attention, and anybody who breaks into the car will be able to drive away. Once they turn the car off they won't be using your key to start it again, but they could be 500 miles away by then.
    VelvetFoot likes this.
  3. Hammersmith
    Hammersmith Senior Member
    2,417
    2,471
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Can confirm that the gen5 does what ChapmanF says about the gen3. A quirk to using the physical key to lock the car is that you also have to use it to unlock it. The smart key buttons and keyless entry are disabled until the physical key is cycled back to unlocked.
    The smart key remote start is limited to 10min and you can only do it twice. I always thought the remote start returns hvac to whatever setting you were using when you shut off the car, but I guess I've never tested it fully.
  4. Mendel Leisk
    42,153
    Google AI tells me New York State has anti-idling laws for large trucks, and New York City has similar for any and all vehicles, 3 minutes city-wide, and one minute near schools.
    If you don't mind, why do you want to do this?
  5. ChapmanF
    18,861
    Part of me looks forward to explaining to the officer "you see, it only idles for a couple minutes at a time, a few times an hour", and part of me does not.
  6. Mendel Leisk
    42,153
    Perhaps that's the reason? If someone manages to break in, take it for a joy-ride, you might see the video on Reddit.
  7. VelvetFoot
    1,388
    538
    New York State
    2026 Prius
    It was a concept.
    Dashcam while parked could be desirable.
    Consumes battery.
    Prius has small battery.
    Thanks for the helpful posts.
