Can I leave my phone charging cord in the power outlet?
Discussion in 'Gen 3 Prius Main Forum' started by massarmor, Jun 13, 2016.
  1. massarmor
    massarmor New Member
    23
    When I'm not in the car and I don't have the phone plugged in to be charged, can I just leave the cord in the power outlet / cigarette lighter input without it draining the power? or any other cord for that matter?
  2. xliderider
    xliderider Senior Member
    7,848
    3,102
    Honolulu, HI
    The outlet is not powered when car is shutdown, so it should be OK.
    Mendel Leisk and Xterra72 like this.
  3. Friend of Bill W.
    109
    164
    Elkhart, IN
    I leave my GPS plugged in, turns off with the car. But I think it still may use a little juice, not sure though.
  4. fuzzy1
    10,045
    With the outlet de-powered -- a necessity these days, with all the battery-killing appliances customers have plugged in -- the GPS can pull that little bit of juice only from its own internal battery, not from the car's 12V battery.
  5. dbf
    dbf Member
    78
    86
    NE Ohio
    FYI- I started to have problems all of a sudden a day or so ago with the 2 cords I leave in the car all the time plugged into a 12v cigarette usb adapter. To make a long story short, I traced the problem to the cords themselves. The end that plugs into the phone was corroded on both cables. They had been setting in a little bit of salt water left behind in the passenger foot area. The water had been left there from people getting in the car with melted snow and salt on their shoes. After replacing the cables, all is working well again. Now we are careful to make sure the ends of the cables are safely tucked away off the floor area.
  6. BZzap!
    BZzap! Senior Member
    1,607
    877
    I don’t understand how the iPhone charge cord can be the problem if there is no power to the 12v power port with the car in the off position. Are you sure you’re not talking about the USB port?
  7. dbf
    dbf Member
    78
    86
    NE Ohio
    There doesn't need to be power to the cord for the corrosion to occur if the cord's unprotected end is setting in water.
  8. Johnny Cakes
    Johnny Cakes Senior Member
    998
    756
    Virginia, USA
    So there's not a problem with your cord draining the battery? That's the subject of this thread.
  9. jerrymildred
    jerrymildred Senior Member
    11,491
    14,100
    Tampa, FL
    I have a 4-port USB splitter plugged into my front 12V outlet. My phone charging cable has been plugged into it for two years. As others said, it turns off when you turn off the car.
  10. BZzap!
    1,607
    877
    Not talking about corrosion. Talking about power outlet being disabled when car is in off position. There is no power to the outlet so how could a corroded cord drain the battery?
    Johnny Cakes likes this.
  11. dbf
    dbf Member
    78
    86
    NE Ohio
    Oops, it looks like I posted to the wrong thread. I was looking for one about problems with charging the phone battery.
  12. BZzap!
    1,607
    877
    Been there, done that.:)
    dbf likes this.
