Can I put a gen 3 (regular) hybrid battery in a 2013 Prius C?
Discussion in 'Gen 3 Prius Main Forum' started by MilkyWay, Dec 17, 2021.
  1. MilkyWay
    MilkyWay Active Member
    819
    357
    23
    MI
    Have a good gen 3 battery sitting around.
    Bought a Prius C says "Check Hybrid System" on dash and I suspect bad hybrid battery.
    With modifications is it possible to put the normal gen 3 battery in? Seen people say the Prius and Prius V are easily interchangeable with mods but didn't come across anything on the Prius C.
  2. Hi_prius3
    Hi_prius3 Junior Member
    46
    Honolulu,HI
    Yes, you can use the gen 3 modules to replace the bad battery pack in the Prius C. The Prius C only has 10 modules while the gen 3 uses 14. I would load test and pick the best modules available so you don’t get any codes. Good luck!
  3. Leadfoot J. McCoalroller
    6,836
    6,483
    Pennsylvania
    2018 Prius c
    clarification: the battery can't be used as is, but the modules inside your spare battery and your prius c battery are the same. One could transplant individual modules, but you don't have the right item to do an instant full battery swap.
  4. MilkyWay
    819
    357
    23
    MI
    Not even with doing swaps/modifications it is physically impossible?
  5. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,476
    Bay Area, California
    2019 Prius Prime
    You mean blocks and not modules;).
    Two modules per block makes 20 modules for the "c" battery (y).
  6. MilkyWay
    819
    357
    23
    MI
    My mechanic will look at when in comes from Texas in a week or 2....But, is the "regular Prius" entire battery assembly too big? As in it is physically impossible to make it fit in the "C"?
    He puts gen 4 motors in gen 3s and is handy so thought maybe we can use the good regular prius battery we have on shelf.
    He can "slap a few cells" in the bad one but I don't like that idea.
  7. Leadfoot J. McCoalroller
    6,836
    6,483
    Pennsylvania
    2018 Prius c
    It's too big.
    The compatibility that you've been hearing about is that the blocks (of modules) inside that shiny metal case are exactly the same as the ones inside the Prius c and Prius v battery cases.
    The difference is the count: the c uses 10 blocks (20 modules) where your stored battery has 14 (28) and the v model has a larger one with more.
    So yes, you could still use the thing you have to repair that Prius c, it just won't be the plugging and playing of one big unit. So that's a very different sort of repair.
  8. Hi_prius3
    46
    Honolulu,HI
    Yes. Thanks for the clarification.
    Raytheeagle likes this.
  9. rjparker
    rjparker Tu Humilde Sirviente
    7,605
    4,460
    Texas Hill Country
    The hatchback and v use the same hv battery
  10. Leadfoot J. McCoalroller
    6,836
    6,483
    Pennsylvania
    2018 Prius c
    Sorry, I must've been thinking of the hybrid camry battery.
    Either way, the 3rd generation battery on the shelf won't fit in a prius c, but pieces of it might.
