Can I remove ugly wheel covers?
Discussion in 'Gen 4 Prius Accessories and Modifications' started by Heather Anderson, May 5, 2019.
  1. Heather Anderson
    Heather Anderson Junior Member
    Cincinnati
    I am about to take delivery of a 2019 Prius LE. Unfortunately, the wheel covers are hideous, but I wasn't interested in upgrading to premium wheels this time. (I have a 2016 Prius currently, and the alloy wheels started to peel and look funky. I don't want to go through that again.)
    I mentioned something to my salesman who is a "friend" about removing the covers altogether and he said it wasn't a good idea, as the covers are there to help with aerodynamics. I do try to get the highest mpgs possible and if it makes a substantial difference, I won't mess with it.
    Btw, I achieved 59.4 mpgs over the 48,500 mile life of my 2016.
  2. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    You'll get used to them. I never noticed them after the first day. They're easier to clean than the raw wheels, and I don't really like them without the covers - which I've seen a couple with no covers (TAXIs mostly).
    Try them for a while. TOYOTA indicate that they help with aerodynamics.
    Heather Anderson likes this.
  3. krmcg
    2,592
    2,390
    Whittier, CA
    I took my wheel covers off at the dealership before I drove my car home on the first day. If there is a efficiency difference with or without I can't imagine it is worth worrying about.
    jb in NE, Heather Anderson and Merkey like this.
  4. Heather Anderson
    Cincinnati
    I've been looking at them for 5 days now and I think I'm ok with the covers. I've seen worse. Thanks for the input.
    alanclarkeau likes this.
  5. alanclarkeau
    7,044
    7,584
    And when it's driving, you can't see them - nor can anyone else!!
    What colour is your car? [you might want to change your profile - from 2016]
  6. Mendel Leisk
    38,644
    If you take off the covers, I'd recommend to get centre caps, cover the small hub openings at centre of rim. Especially if you're in an area with salted roads through winter. This I believe is the correct Toyota cap, though there might be cheaper EBay knockoffs by now:
    Center Cap - Toyota (42603-52170) | Toyota Parts
    Also, consider getting a touch-up paint, in CLASSIC SILVER METALLIC 1F7, should be a perfect match for the rims. It's good for curb rash, and I suspect the Toyota wheel cover jaws chew up the alloy rims a bit.
  7. jb in NE
    jb in NE Senior Member
    2,233
    1,596
    Nebraska
    2018 Prius Prime
    Get a can of Fluid Film and spray in the hole where the centre caps would cover. This will coat the metal and prevent corrosion.
    The Electric Me and Mambo Dave like this.
  8. Mendel Leisk
    38,644
  9. timothevs
    timothevs Junior Member
    Tampa
    2019 Prius
    I see a lot of aftermarket options for snap on wheel covers that look better than the monstrosity my LE shipped with. Does anyone have any experience with these aftermarket wheel covers?
  10. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    You could just paint the covers trendy gloss black. :cool:
  11. timothevs
    Tampa
    2019 Prius
    Very true, some very good examples on this forum. I think I will do just that. Thank you!
  12. LewLasher
    LewLasher Member
    244
    66
    Cambridge, Massachusetts
    2019 Prius
    XLE AWD-e
    The problem that I'm having with the wheel covers is that it makes it harder to unscrew the caps off the valve stems to check the tire pressure. Once I accidentally dropped the cap under the cover - yes, my life really is that tragic - and so I had to figure out how to remove the wheel cover and then put it back securely. And, that much more work when swapping the snow tires.
    I'm seriously getting the little center caps.
    Lew
    Mambo Dave and krmcg like this.
  13. Mambo Dave
    Mambo Dave Active Member
    640
    306
    2019 Prius
    L Eco
    I'm surprised at how heavy, but also sturdy, the wheel covers are.
    Center caps are on their way to me, here, probably arriving toward the end of the month.
    krmcg likes this.
  14. Mark Carnahan
    Mark Carnahan Junior Member
    Ohio
    Try Plastidip. Peels right off if you get tired of the color. Sprayed my 4Runner's wheels Anthracite gray and it's still solid after 2 years.
  15. Mambo Dave
    640
    306
    2019 Prius
    L Eco
    I think he was joking. Don't do that.
    The wheels look great without the covers.
    RMB, krmcg and Mendel Leisk like this.
  16. Mendel Leisk
    38,644
    I suspect he wasn't joking, but agree: not a fan of black rims. Well, I'm currently using black steel rims with snow tires through winter, but they're definitely not lookers.
  17. krmcg
    2,592
    2,390
    Whittier, CA
    When I took my wheel covers off I thought it improved the overall look of the car a lot! I painted my brake calipers red and that gave a real pop of color.
    Mambo Dave likes this.
  18. Mambo Dave
    640
    306
    2019 Prius
    L Eco
    Black wheels are one thing; black Prius hubcaps would be hideous.
    krmcg likes this.
  19. Mambo Dave
    640
    306
    2019 Prius
    L Eco
    Hey - since you've done it, what torque are our wheels supposed to be tightened to?
  20. krmcg
    2,592
    2,390
    Whittier, CA
    Don't know. I spent years in the tire installation business and learned to basically ignore lug nut torque settings. Righty-tighty...
