Can I replace this myself?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Daniel Kutcher, Aug 24, 2021.
  1. Daniel Kutcher
    Daniel Kutcher Junior Member
    30
    Richmond, Virginia
    This small piece of rubber trim (molding?) is pulling away from the body. What is this piece called? Can I replace this myself?
    Ps - I temporarily filled in the gap with some black silicone to keep it water tight,
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,961
    4,709
    Texas Hill Country
    You can always stop at the dealers parts dept. If the price is outrageous then go elsewhere. One option is the junkyard.
  3. rjparker
    7,961
    4,709
    Texas Hill Country
    Check with dealer parts dept
  4. ChapmanF
    15,563
    That's usually the way it works, which is why when you go to parts.toyota.com there are diagrams. :)
    Looks like you're wanting the part there that is called out as 53866, which is seal, front fender to cowl side, right.
    xliderider likes this.
  5. Mendel Leisk
    38,706
    That's a little alarming; parked outside a lot?
    I think you'd have to partially remove the fender. Info's not in Repair Manual, as far as I can see. I believe there's a separate manual for bodywork?
    Might be simple enough: I see there's one bolt up at top of front/right door jamb, and several in the seam (in engine bay) along top of the fender.
  6. ChapmanF
    15,563
    Sometimes it's helpful to just go buy the part (just $10 at the dealer) and look at it closely, which will sometimes suggest what's involved in replacing it.
  7. Daniel Kutcher
    30
    Richmond, Virginia
    Thank you thank you! I wasn’t being lazy. I really did try to find this on my own. Practice makes perfect.
  8. Daniel Kutcher
    30
    Richmond, Virginia
    Just realized that this piece is sandwiched between the windshield gasket and the body. So I guess I will wait until I replace my windshield (which I need to do).
  9. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    I'd be really surprised if it was that cheap at a dealer.
    IIRC a single replacement roof rack rubber filler strip was something like $75......and that was maybe 5 years ago.
  10. ChapmanF
    15,563
    If I hadn't just linked to it in the OP's other thread, I probably would have hedged more.
    #10 ChapmanF, Aug 24, 2021
