Can I resuscitate a weak hybrid-battery + battery block after lack of driving?
Discussion in 'Gen 2 Prius Main Forum' started by priuslyfe, Apr 10, 2026.
  1. priuslyfe
    priuslyfe Member
    295
    70
    I'm kinda confused how to ask this question tbh. Sorry if this problem lacks clarity. I guess the I'm just trying to say I would rather not have to worry about a hybrid-battery when I have to replace an actuator anyway in one of my Prius. I have two Gen2 Prius.
    PRIMARY DRIVER: 2007 Prius has bad actuator and cannot drive but the hybrid-battery is good.
    SPARE DRIVER: 2008 Prius has bad hybrid-battery (CODES BELOW) I suspect because although I've started it semi-regularly and let it run for 30min to an hour I haven't driven it at all this past year.
    My options are:
    A) Drive the undriven 2008 Prius and resuscitate the battery (hybrid) if possible. But it has the folowing bad battery codes
    B) If the ABOVE isn't an option and I can't drive it back to health, then I would have to swap the good-HYBRID battery from my 2007 Prius to the 2008 Prius (which would leave me shopping for a new HYBRID battery for the broken 2007 Prius plus having to replace the actuator). I don't mind because the weather in Ohio is better, but would like to avoid this option. The weather in Ohio has been brutal this past winter and the 2008 Prius has had to endure the cold-weather. Mentioning this because it might affect the outcome.
  2. pasadena_commut
    pasadena_commut Senior Member
    2,933
    885
    Southern California
    Seems like these are the most likely issues:
    1. The pack is just out of balance because it has not been driven enough.
    2. Corrosion on the bus bars/nuts.
    3. The indicated module has actually gone bad.
    What are the battery voltages?
    If the voltages are just outside of the "good" limits I would be tempted to fire the thing up and drive it around for a couple of hours. Just not too far from home. Then check the voltages again. I'm not entirely sure that you can get it back into balance this way though. It may still be salvageable, but only with some time on a grid charger.
    However, if the voltage on the indicated module is way off then pull the safety latch, open the pack case, and look for corrosion. At the same time measure the voltage on the bad module directly. That should settle the matter for (2) and possibly (3).
  3. priuslyfe
    priuslyfe Member
    295
    70
    not sure the battery voltages yet. been putting off doing any thinking about it due to the weather. gonna check tomorrow morning.
    i have read about driving it and that is what I apprehensive about. Supposedly, it needs varying speeds and distances, but because of uncertainty I don't want it to die on the highway.
    BTW It has the RED TRIANGLE that pops up after some time on 20min or so.
    EDIT: not sure exactly how to read voltages yet. did battery test on Dr. Prius said block 3 bad though.
    #3 priuslyfe, Apr 10, 2026
  4. Brian1954
    Brian1954 Senior Member
    2,493
    998
    South Central PA, USA
    The two Dr Prius screenshots that you posted are for the app in Demo Mode. They are not for the hybrid battery in your Prius. Demo Mode is to show the user an example of how the app works. Now, you need to learn how to use the app when it is connected to the car's OBD2 port while using a Bluetooth dongle.
  5. priuslyfe
    priuslyfe Member
    295
    70
    thanks. I wasn't sure as it asked me to accelerate and decellerate. LOL.
  6. Brian1954
    2,493
    998
    Have you looked at the DrPrius website? One page on the website shows OBD2 Bluetooth dongles that are recommended to be used with the app. They also show some that will not work with the app.
    Did you buy a recommended OBD2 Bluetooth dongle to use with the app.
  7. priuslyfe
    priuslyfe Member
    295
    70
    I'm not sure. I used the same one I use with my Autel MaxiAP200 app, can i use that app to read the battery (i suspect not)?
    Is there a certain-type that is needed to use the Dr. Prius?
    Tbh I'm not sure what I'm doing or how to read the voltages or readings anyway.
  8. pasadena_commut
    2,933
    885
    Southern California
    Pretty sure the AP200 dongle can read the voltages too. Not sure if Dr. Prius can access it, it may not be Elm327 based. The Autel dongle and software does most of what Techstream does, and Techstream can read them. Heck, Torque Pro can read them using a Veepeak dongle, at least after the Prius specific PIDs are loaded and you laboriously create a display for each value. See this thread:
  9. priuslyfe
    priuslyfe Member
    295
    70
    thanks. will look into it this weekend.
