Can I retrofit an XLE headlight switch on an LE?
Discussion in 'Gen 4 Prius Accessories and Modifications' started by David9962000, Aug 1, 2020.
  1. David9962000
    David9962000 Member
    139
    66
    2020 Prius
    I would like to get the Auto feature. I believe the LE has all the needed sensors?
    Thank you.
  2. Elektroingenieur
    2,515
    3,259
    Three Touring
    The Electrical Wiring Diagram (more info) shows that the AUTO and DRL switch positions are electrically the same. The functionality depends on programming in the Main Body ECU (Multiplex Network Body Computer), and I’m not sure what else might happen if you replaced that ECU with one from a different grade.
