can i sawp out my own headlight
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Whiteyprius, Nov 22, 2014.
  1. Whiteyprius
    Whiteyprius Active Member
    389
    105
    North Carolina, USA
    My Prius is a 2012 Two model. The headlight is my low beam on the left side. Is this something I can so myself? Thanks!
    phil via Nokia
  2. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Yes. Swapping out the headlight bulb are pretty easy.
  3. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Yes, not too hard. Take your time, and DON'T touch the new bulb "glass". Fingerprints will make it fail early. If it has been touched (you can see marks such as fingerprints) clean it with an isopropyl pad (those packaged ones you see for cleaning whatever) or just glass cleaner.
  4. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    Just wear nitrile gloves when handling the bulbs.
  5. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Or, don't touch the bulb, handle it only by the base. ;)
    The driver's side bulb is actually much easier to change than the passenger side. If you are changing a burned out bulb, you should replace both sides at the same time. Keep the old bulb as a spare though.
    SCH-I535
  6. budrow56
    budrow56 Junior Member
    45
    There are enough you tube videos that can guide you . But if it's still in warranty have the dealer do it.
