Can I tel lithe age of a battery?
Discussion in 'Gen 2 Prius Technical Discussion' started by lordofthereef, Mar 11, 2020.
  1. lordofthereef
    lordofthereef Junior Member
    61
    I have a battery on marketplace that the owner states is less than a year old. It was installed by Toyota into a 2007 Prius which was then in an accident. Seller is effectively parting out.
    is there a way to tell the actual age of the battery by looking at it (or serials and etc). He's going to look and see if he can find paperwork on the install for me. But short of that, can I confirm it's build date somehow?
    asking price is $400.
  2. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,317
    Central Virginia
    @TMR-JWAP You are one of the battery experts.
    lordofthereef likes this.
  3. fotomoto
    fotomoto Senior Member
    5,596
    3,770
    So. Texas
    Never seen an OEM painted case. Look closely at the stickers, they've been masked for painting with some red overspray (there's your sign).
    The absolute best way to determine age is to remove the cover and review the date codes on the modules. I'd wager that one is a rebuilt and has modules from several different years.
    GOOD LUCK!
  4. Prodigyplace
    11,696
    11,317
    Central Virginia
  5. SFO
    SFO Senior Member
    5,286
    4,225
    Northern California
    The 'advance search' feature still works for some reason o_O
    https://attachments.priuschat.com/attachment-files/2018/08/152015_TSB_T_TT_0365_15_battery_identification.pdf
    If this was installed by Toyota, there would be associated service history. Ask for the VIN and look it up at http://toyota.com/owners
    You could also take the VIN to a dealer (or over the phone), and they should tell you if the HV battery was replaced and when.
    If the service is listed at Toyota, then remove the cover from the battery case to confirm that the module serial #s match one another.
    2x on what @fotomoto said, never seen a painted case from a dealer.
    Raytheeagle and lordofthereef like this.
  6. lordofthereef
    61
    I appreciate the info. I didn't know if maybe newer production units were painted differently or something.
    What's the purpose of third parties painting it? Seems like an unnecesssry step.
  7. Prodigyplace
    11,696
    11,317
    Central Virginia
    It does mean you should not trust the battery.
  8. lordofthereef
    61
    Thank you. I did do a search and didn't come up with anything like this. All I saw were questions about batteries still in vehicles and the recommendation was to go by VIN.
  9. lordofthereef
    61
    Thanks. This was very helpful.
    This is a wonderful forum. Just kept me from making a $400 mistake.
    Raytheeagle and Prodigyplace like this.
  10. Prodigyplace
    11,696
    11,317
    Central Virginia
    By the way, they lied.
    Toyota only installs NEW battery packs.
  11. fotomoto
    5,596
    3,770
    So. Texas
    I've completed enough orbits around the sun to finally get it thru my hard head that the answer to nearly all questions about human behavior is....... money.
    lordofthereef and Prodigyplace like this.
  12. SFO
    SFO Senior Member
    5,286
    4,225
    Northern California
    There was a brief moment in time where Toyota offered and installed refurbished packs, but it didn't last long.
  13. dig4dirt
    dig4dirt MoonGlow
    1,150
    741
    Lancaster Co PA
    2014 Prius c
    Is that one of those kidney bean batt jobs?
  14. lordofthereef
    61
    Haha. Understood. I'm just trying to understand how painting it red translates to a better product?
    Only thing I can think is a local place reconditions them and paints them red to "mark" their work?
  15. lordofthereef
    61
    Idk. I though green bean does green. It's the only color I had seen before. But I'm the farthest in these forums from k owing anything lol.
  16. Prodigyplace
    11,696
    11,317
    Central Virginia
    I understood it was only a small number of dealers in California.
    SFO likes this.
  17. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    You could take it to Toyota and ask them but the serial number would usually tell you
  18. TMR-JWAP
    TMR-JWAP Senior Member
    6,058
    5,783
    Columbia, SC
    @Prodigyplace is 100% correct. The manufacture date of the CASE is 8/24/2006. That doesn't mean the modules are the same. You would need the serial numbers from the tops of a few modules.
    On a module:
    1. the first 2 digits are the day of the month
    2. the next digit is the month (1-9, x, y, z)
    3. the next digit is the year, with L being 2010. (M=2011, etc)
    On a CASE, with that style sticker:
    1. the first digit is always a letter code designating what vehicle the battery is intended for. (prius, camry, etc)
    2. the next 2 digits are the day of the month
    3. the next digit is the month (same as #2 above)
    4. the next digit is the year, with L being 2008.
    Prodigyplace likes this.
  19. Prodigyplace
    11,696
    11,317
    Central Virginia
    Any idea who paints the pack red? I know you have accepted several bad rebuilt packs after people gave up on them.
  20. TMR-JWAP
    6,058
    5,783
    Columbia, SC
    Red is a bit funny for me. Over the weekend, I was shopping for some parts for my sand blaster, because I have several gen 2 cases I'd like to blast and paint. Nice condition cases are getting hard to find, as most cores seem to always have those large corrosion stains. I had looked around at colors other places were using, and even did a google search to see what color was most associated with Toyota (like Blue is a Ford thing). Guess what came up as "Toyotas color? Red. Since I also didn't see any other rebuilders using red, I thought I'd use it. Not anymore. Sigh..........back to the search...
