Can I top off coolant with another brand as long as it's pink ?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tom Mayor, Feb 27, 2023.
  1. Tom Mayor
    Tom Mayor Junior Member
    52
    Orlando
    Happy Monday everyone,
    I would like to know 2 things,
    I drive a 2010 148 000 miles Prius.
    Is it OK to top off with another coolant brand as long as it's pink? I don't know what's the brand in the reservoirs.
    I also plan to flush and poor new coolant (it's due) in the following days, Can I use 2 different brands like Peak and Zerex, still as long as it's the pink version, good for my Prius ?
    Thank you so much!
  2. ColoradoBoo
    ColoradoBoo Senior Member
    1,241
    833
    Monument, Colorado USA
    Personally, no, I only use Toyota coolant in my Toyota's. (Same for transmission fluid.) Your local dealership will have them in stock. But, if you don't want to go there, ensure it says it's compatible with Toyota's.
    It's, also, not normal to have to "top off" coolant reservoir unless the car was recently serviced and bleeding out air from the lines/engine. You may want to inspect to see if there are any new leaks...it will be pink in color.
  3. alftoy
    alftoy Senior Member
    1,132
    517
    Saskatchewan, Canada
    Aren't you supposed to get Toyota coolant for Jerry Mildred so he can service your Prius.
  4. rjparker
    rjparker Tu Humilde Sirviente
    10,164
    6,319
    Texas Hill Country
    Buy a $1 gallon of distilled water and top off with that unless you buy a gallon of the Toyota premix.
  5. ASRDogman
    ASRDogman Senior Member
    7,603
    3,915
    Why do you need to "top it off"?
    Is there a leak? Or a possible head gasket failure?
    How much are you talking about? Is it just below the full line, or way below it?
    If it's just below the line, you can add distilled water. Then check it every day or two.
    If it doesn't go down, you're okay. But could be due for a coolant change.
    When was it changed last? How many miles..
  6. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Toyota formula has Phosphate cavitation enhancer so make sure whatever pink you use has that…
  7. PriusCamper
    PriusCamper Senior Member
    12,789
    5,179
    Pacific Northwest, USA
    Won't be an issue temporarily, only long term... And because your loss of coolant is highly likely due to a chronic problem with early headgasket failure in Gen3 Prius you'll be draining all the fluid soon anyways, to have the headgasket done. Sometimes you can get a year or more out of a failing headgasket if you only take short trips and avoid hot weather.
  8. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    The Toyota dealer is two miles from my house. If we need more than what you're bringing, it won't take long to get it.
