Can I use a Small Lead Acid Battery instead of a AGM Battery?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by THADTHOMPSON, Aug 30, 2018.
  1. THADTHOMPSON
    THADTHOMPSON New Member
    LA
    Is it ok to use a small lead acid battery in place of the original AGM battery. Could I damage something?
  2. Patrick Wong
    18,200
    6,479
    You won't damage the car, however this potentially may create a safety issue to the extent that if your car gets hit in the right rear fender and the battery case is impacted, you will have battery acid sprayed around the rear hatch and possibly into the rear seat area.
    At minimum, make sure that the battery case has the positive terminal on the left side of the case when viewing the battery with the terminals on the side closest to you. If the terminals are reversed and you install the battery with the terminals adjacent to the fender, that constitutes another safety hazard to the extent that if that fender is impacted into the battery and contacts the positive terminal, an electrical short may result.
    #2 Patrick Wong, Aug 31, 2018
  3. JimboPalmer
    12,470
    6,870
    Greenwood MS USA
    All the important features of a prius battery feature in passenger safety.
    AGM means less acid to spread in a wreck.
    Externally vented means less sulfuric acid and/or hydrogen gas in the cabin with passengers
    JIS Posts are just odd, no US battery will fit them, you would need to replace the battery cables as well as the battery
    Installation Kit for Optima battery in Prius
    Here is a cheap 'correct' battery
    www.amazon.com/dp/B010GKJ8F6/
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,790
    2017 Prius c
    Two excellent answers already.
    Pay attention to what both of them said.
    Nothing much else needs to be said.
  5. exstudent
    exstudent Senior Member
    2,214
    901
    Torrance, CA
    #5 exstudent, Aug 31, 2018
  6. THADTHOMPSON
    LA
    Thanks! Yes all very helpful. Just wanted to know if it would damage something. I had to use one temp until Amazon delivery.
