Can I use P185/65r15 tires on Gen3?
Discussion in 'Gen 3 Prius Main Forum' started by NinnJinn, Jun 7, 2020.
  1. NinnJinn
    NinnJinn Member
    276
    Indiana
    Today I purchased a 2012 Prius 2.
    I understand with the Generation 3 they come with The p195/65 R15 tire .
    With the car that I purchased today might have 5 to 10,000 miles left on those tires
    I have a 2008 Prius that I will be selling off as Parts only but the P185/65r15 tires are 3 months old and have less than 5,000 miles on them.
    The person that is interested in purchasing my 2008 Prius could care less what tires are on it.
    So can I take the OEM size tires of a generation 2 Prius and put them on a generation 3 Prius??
    If I'm able to then once the generation 2 oem size tires need replaced I will be going back to the Generation 3 OEM tire size.
    douglasjre likes this.
  2. High Mileage
    High Mileage Active Member
    135
    231
    2018 Prius Prime
    I ran a set of 185/65/15 Bridgestones I my 2010 Gen 3 with no problems.
    douglasjre and NinnJinn like this.
  3. ttou68
    ttou68 Active Member
    345
    203
    Ditto, Gen 2 tires are fine with Gen 3...
    Only one thing of concern is TPMS....
    Gen 3 rims has Tire Pressure Monitoring Sensors, and Gen 2 doesn't. You may want to swapping out the sensors to the rims you are using, or you will see tire pressure warning light on dash...
    Tire Size Calculator
    #3 ttou68, Jun 7, 2020
    NinnJinn likes this.
