Can I use this old 12v battery-charger to charge a Hybrid-block?
Discussion in 'Gen 2 Prius Main Forum' started by priuslyfe, Apr 13, 2026.
  1. priuslyfe
    priuslyfe Member
    317
    70
    I know the modern chargers have digital readings but this older one (from the 1990s I think) doesn't really have an exact reading to see whether or not its overcharging. Trying to see if I can recharge bad-blocks prior to buying a replacement.
    thanks.
  2. Tombukt2
    Tombukt2 Senior Member
    13,708
    2,482
    Durham NC
    But this is putting out 12 volts you're reading charging T what 8v or such
  3. Leadfoot J. McCoalroller
    8,213
    7,718
    Pennsylvania
    2018 Prius c
    That charger is designed for a different battery chemistry.
    It could theoretically charge a block of Prius batteries, but you would not be able to trust its "fully automatic digital smart control" system. That is kind of a big deal- you'd need to set up a voltage meter and be ready to intervene if anything went sideways.
    In other words you would want to watch it like a hawk for fire safety, and it wouldn't necessarily be the kindest way to charge that block. But it could be done.
  4. priuslyfe
    priuslyfe Member
    317
    70
    so a dead or bad block would be a hard-no then. DANG!!
  5. priuslyfe
    priuslyfe Member
    317
    70
    UPDATE:
    I managed to use the above charger for a hybrid battery cell. it can be used you just have to monitor it. I had a battery cell that had 6.5 voltage and after 30 minutes it went up to 8.3V. After resting it went back down to 8.0. The rest average between 7.4V and 7.6V.
    HOWEVER, there is a string of 4 blocks that are not accepting charging and immediately going into "fault" i assume because of low charge. There are 8 cells or 4 blocks on the passenger side of the battery (away from the connectors).
    For dead 12V batteries I know you can trick 12V batteries to charge by using jumper cables connected to a dead 12V battery and then connecting the other end of the jumper cables to the healthy 12V battery (also you while charging this healthy battery). it tricks the dead 12V into waking up.
    should I attempt this with the hybrid battery dead-cells that are dead/low voltage?
  6. dolj
    dolj Senior Member
    8,624
    4,376
    Wellington, New Zealand
    What you mean is, "I had a battery module that had 6.5 volts ... There are 8 modules or 4 blocks"
    There are 6 cells in each module that are inaccessible due to the sealed nature of the modules.
    Brian1954 likes this.
  7. priuslyfe
    priuslyfe Member
    317
    70
    thanks.
    I think the "trick" above did work at least to get it to accept charge. I only did it for about 2 minutes and then hooked the module back to the 2amp charger. I plan on checking it every 20 minutes.
    Is there a way to discharge/charge a module without a specific machine to do that? will just letting it discharge by itself be sufficient. to paraphrase, I mean charging each module and then letting the battery sit for days/weeks and then charging again after it loses some voltage.
  8. dolj
    dolj Senior Member
    8,624
    4,376
    Letting the modules self-discharge over time is useful to gauge the health of a module, if you have the time to wait. A healthy module's self-discharge rate will be slow. One that discharges quickly to a low voltage is suspect.
    To actually recondition the modules, you need to have a resistor pack of some sort to apply a load to discharge the module(s) to whatever voltage you need, being careful to use a current of 250-300 mA load (or less) below 195 V to limit potentially damaging (irreversibly) the module(s). The light bulb discharger that HA sells is one (or you could build your own), you could use.
  9. priuslyfe
    priuslyfe Member
    317
    70
    Is there any way to rig these modules with what little I have? I don't want to buy too much more because this hybrid-battery is going in my SPARE PRIUS.
    I'm already on the fence about just selling the car for $1000 or so including the hybrid-battery if I can get it to work. I figure some delivery driver might like it as many of them know how to rig the entire Gen 2 prius on the cheap anyway.
  10. highmilesgarage
    highmilesgarage Active Member
    494
    182
    Kansas City
    you can buy this cheap charger and a 12v lightbulb (headlight for discharging) It will be a slow process, better to invest in a hobby charger with automatic charge/discharge cycles ($$$) OR just buy a used battery pack from 2nd life, Greenbean or Greentec for $1000..
    if the discharge rate (using the bulb) is faster after fully charging then you eventually need to a buy a module which costs $75 (?) each. So you'll still end up with money to spend..
