Can I uses regular oil vs. synthetic?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by dimodica1, Jan 5, 2012.
  1. dimodica1
    dimodica1 New Member
    The other day Speedy Oil changed my oil and put in regular oil vs. synthetic. I questioned them on that and they said unless it is marked on the oil cap or something like that, I could use regular oil.
    I have 25,000 miles and always had the synthetic.
    Should I be worried?
  2. Joe166
    Joe166 New Member
    720
    97
    South Florida
    No, but you can't go the regular interval. You need to change it more quickly. That is assuming that the "regular oil" they used meets the manufacturers spec, which brings us to the next point.
    What you should be worried about is the use of quickie, franchised oil change operators. That is sometimes quite risky. Check the ground under your car frequently. Try to get "proof" of the actual kind of oil they used and then compare it's specs to the requirement set by Toyota. Unless the one you went to is unusual, these places are usually manned by minimum wage people with minimal training and experience.
    Most dealers have competitive prices and you have the advantage that there is a computer record, available to any Toyota dealership, to prove the fact that you changed your oil religiously.
  3. Mendel Leisk
    40,584
    Do you know what grade they used?
    My 2 cents: I'd avoid those sorts of operations.
    Lukey51 likes this.
  4. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    Did it meet the minimum specifiations for an oil change on the Prius? If it did, change after 5,000 miles. If not they shouldn't have changed it. The manufacturers publish the oil requirements for vehicles and those should be available on a database. If they don't have it they can check the user manual (assuming it's in your car). If that's not available they should look it up. Basically, don't go back there. They don't need experts. They just need an adequate system.
  5. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    it is my understanding that you cannot make 0W20 conventional oil, so if they used non-synthetics they must have used 5W20. If 5W20 used Toyota recommends 5,000mi interval. They also recommend to switch back to 0W20 as soon as possible, and they say not to used it in cold weather.
    Mobil 1 0W20 is 26$ per 5qt in Walmart, filters are 4-5$ at dealer. Do your own oil changes good luck.
    Lukey51 likes this.
  6. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Buy your own oil and filter, whatever you like, let the dealer do the work and dispose of the used oil properly!
    Anything is better than JiffyStupid etc....
    Lukey51 and almypal26 like this.
  7. pjksr02
    pjksr02 Active Member
    532
    226
    Connecticut
    I'd be concerned they didn't change the filter element, or if they did, that they installed the housing improperly.
    I'd be really concerned about the condition of the push-pins on the oil-change door.
    You're not going to sleep well!
  8. The Critic
    The Critic Resident Critic
    3,193
    2,327
    CA
    Quick lubes are already familiar with our cartridge filters since the newer Corollas also use them. So, there is no need to be paranoid.
    Conventional 5w20 is perfectly OK at 5,000 mile intervals per the manual. It is the more cost effective option if you are only paying $30 for an oil change every 5k compared to $75 for a synthetic 0w20 oil change every 10k.
    More importantly, if an individual only drives their vehicle on shorter trips around town, they are much, much better off using conventional 5w20 at 4-5k intervals than synthetic 0w20 at double the interval. The nasty fuel dilution is removed much sooner with more frequent oil changes. The viscosity difference between the ultra-thin, high VI Toyota 0w20 and a conventional 5w20 is also minimal, and the fuel economy difference will be negligible to most people.
  9. cyclopathic
    3,292
    547
    2014 Prius c
    5W20 vs 0W20 is true in warmer climate but could bite with winter temps well below freezing.
    Yes changing oil at shorter intervals with short trips will help with fuel dilution, but not so much with deposits. Conventional oils contain paraffin, they burn at lower temperatures, they don't have as many detergents.
    Per my mechanic with 30+ years of experience most of the engine/oil issues in engines he worked on were due to deposits, not b/c premature wear. 2nd biggest issue was due to valve seal wear (rubber gets cooked) he recommended changing seals with quality nitrite ones on 5-8 year old/150-200K engines as a way to extend engine's life.
  10. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    It is printed on the cap - "0W20"... that is only available in synthetic.
  11. The Critic
    3,193
    2,327
    CA
  12. cyclopathic
    3,292
    547
    2014 Prius c
  13. Mendel Leisk
    40,584
    Really though, having an earnest debate with Speedy Lube regarding oil grades and so forth, is pretty much on par with discussing your parrot's state of health with the Pet Shop owner in the Monty Python sketch.
  14. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Lets not be impugning the veracity of Python's Pet Shop owner.:D
  15. Flyman
    Flyman Junior Member
    64
    Packwood, Washington
    I'd change my own oil before using Jiffy Lube or any of it's ilk. I don't trust them or much of anything they say.
    Lukey51 likes this.
  16. mickey513
    mickey513 Member
    127
    Cali
  17. ETC(SS)
    6,958
    You joined the forum in '07, have like....3 posts, and 25K miles on a G-something, either 2 or 3.
    Interesting.
    OK.
    Here's the deal.
    Cartridge filters aren't new...not even close, and the manual says you can use 5w30 with modified intervals----so no.
    I wouldn't lie awake at night worrying that you've wrecked your engine.
    I'm sure that Joey Bagadoughnuts down at the EARL EMPORIUM did his (or her) usual stellar job, and he (or she) didn't use bulk oil in a 55-gallon drum, overtorque your filter housing or drain plug, or anything like that. I'm also sure that you've already checked to make sure that Joey didn't over fill the oil---so I'm 99.44 percent sure you'll be fine.
    As long as you're changing your oil per the OEM maintenance schedule or having it done by a "qualified" wrench, you're "probably" going to be OK---especially if you plan to put less than lunar mileage on your vehicle. Just remember that while Joey might be a pretty good wrench, he (or she) doesn't care as much about your car as you do, and the difference between a $70 oil change and a $30 oil change even every 5K for a $25,000 vehicle just doesn't justify wandering too far from the OEM maintenance schedule.
    YMMV...
  18. oldasdust
    oldasdust Member
    356
    47
    illinois
    How many quarts of the dino oil did they use? Replace the drain washer ?
  19. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    You can say that again. Cartridge oil filters have been around since at least the 1920s. Spin-on's didn't show up on mainstream production cars until 1957 (FoMoCo for sure and I think Chrysler). Fram had a spin on they made for 1952 Crosleys.
  20. tumbleweed
    tumbleweed Senior Member
    4,067
    690
    Eastern Oregon
    What year is your car? What weight oil did they use? Did they change the filter?
    If your car is a 2010 or 2011 and if they used 5W20 and changed the filter you can go 5K miles to the next change without violating the warranty requirement, but then you must use 0W20 at the next change. With 0W20 you can go 10K miles between changes.
    If your car is older that 2010 you can probably use 5W30 non-synthetic (but synthetic would be better) and change every 5K miles.
