Can install fog lights on Prius c Three?
Discussion in 'Prius c Accessories and Modifications' started by priusmatty, Jun 3, 2016.
  1. priusmatty
    priusmatty Active Member
    304
    108
    Louisiana USA
    2020 Prius
    L Eco
    The only thing on Four I really want are the fog lights, I think. I absolutely hate parts on cars that are like dead buttons, dead pedals, or filled in fog light receptacles haha...it annoys the heck out of me. That is really the one reason I want a four. Does anyone know how much it might cost to install fog lights on a three?
  2. Squeakasaur
    Squeakasaur Member
    106
    35
    22
    Seattle
    2016 Prius c
    priusmatty likes this.
  3. priusmatty
    304
    108
    Louisiana USA
    2020 Prius
    L Eco
    The fog lights are not LED??
  4. JimboPalmer
    12,470
    6,870
    Greenwood MS USA
  5. Squeakasaur
    Squeakasaur Member
    106
    35
    22
    Seattle
    2016 Prius c
    I don't think so. But they are super bright. I can take a picture for you if you want?
  6. priusmatty
    304
    108
    Louisiana USA
    2020 Prius
    L Eco
    That would be great. Thank you!
  7. Squeakasaur
    Squeakasaur Member
    106
    35
    22
    Seattle
    2016 Prius c
  8. priusmatty
    304
    108
    Louisiana USA
    2020 Prius
    L Eco
    Thanks very much. They look very bright.
  9. Squeakasaur
    Squeakasaur Member
    106
    35
    22
    Seattle
    2016 Prius c
    Yeah they match very well with the projector headlights. I hate it when a car has the projector headlights but halogen fog lights
  10. Bigboi
    Bigboi Member
    136
    26
    Las Vegas
    2015 Prius c
    Arent foglights included in the C4 trim since its the highest trim? I would go back to the dealer and say hey man, you guys need to give me my fog lights
  11. Christophers
    Christophers Active Member
    269
    105
    Honolulu
    2015 Prius c
    2015-2016 c has led fog lights out the factory. I got priced something around 1k to instal the fog lights with parts and labor. eBay has kits for the 15-16 but they are hologen bulbs and have a separate button for the fog light other than being on the stalk. They run around $175 ish.
  12. priusmatty
    304
    108
    Louisiana USA
    2020 Prius
    L Eco
    So does this mean that all exterior lights on the 2016 Prius c are LED?
  13. Christophers
    269
    105
    Honolulu
    2015 Prius c
    Yes pretty much. The head light and fog lights are led. Also the tail lights are also led. I was going to change the bulbs but found out I don't have to.
  14. priusmatty
    304
    108
    Louisiana USA
    2020 Prius
    L Eco
    Are the indicators also LED?
  15. Christophers
    269
    105
    Honolulu
    2015 Prius c
    You mean the blinkers on the bumper. I haven't checked. But would be wasteful anyway to change it since it's a dual bulb. Might throw off weird signal and cause quick blinking. As for the mirrors i think they kept with the bulbs that are built into the mirror if im not mistaken.
  16. priusmatty
    304
    108
    Louisiana USA
    2020 Prius
    L Eco
  17. Squeakasaur
    Squeakasaur Member
    106
    35
    22
    Seattle
    2016 Prius c
    Christophers is right, I just checked and the toyota website says:
    "This is style you can count on. Prius c stands out with standard single-LED projector low- and high-beam headlights and available LED fog lights set in an aggressively styled grille. Prius c helps you leave a small footprint while making a big impression."
    Also
    "Just a friendly heads up: other cars will be slowing down to get a better look at Prius c’s taillights. Their vibrant LED design helps you show off your expressive side, and the sporty rear bumper reminds everyone that this hybrid is always up for some fun"
    Not seeing anything about the blinkers tho
  18. JimboPalmer
    12,470
    6,870
    Greenwood MS USA
    http://www.toyota.com/t3Portal/document/om-s/OM52F96U/pdf/OM52F96U.pdf Page 535
    Light bulbs W Type
    Exterior
    Front turn signal/parking lights 28/8 B
    License plate lights 5 A
    Back-up lights 16 A
    Side turn signal lights 5 B*2
    Front side marker lights 5 A
    Rear turn signal lights 21 B
    Interior
    Interior lights/personal lights 5 A
    Luggage compartment light*1 5 A
    *1: If equipped
    *2: Side turn signal lights should be replaced as an assembly
    A: Wedge base bulbs (clear)
    B: Wedge base bulbs (amber)
    These are all incandescent from the factory. (I do not know how to format a table)
  19. Masterloc
    Masterloc Junior Member
    53
    New York
    2015 Prius c
    A little bit of help here?
    I bought a fog light kit for the 2015 Prius C. Instead of using the supplied wire and harness, I'm plugging in the fog lights to the Factory wires.
    But I'm not going to spend another 100+ for the stalk. Where can I splice the fog switch to? This is the flat switch pictured in many of the fog light instructions for earlier Prius C model. But none really mention how to connect the switch when using factory wires.
    I tried to take the steering wheel out, but so far, no luck. No idea how to remove it, so I can't exactly see where the stalk connects to.
    The switch has 4 wires coming out of it. 1 black, 2 red-black, and 1 green. the 2 red-black connects together at some point and became a purple wire. so in all, I have 3 wires to work with. 1 black, 1 green, and 1 purple. I believe the black is ground, so that's not a problem. the green would be toward the fog, and purple to hot? That's just my guess.
    Thanks.
  20. Priusc-2
    Priusc-2 Junior Member
    27
    Cali
    2015 Prius c
    There is a connector on the driver side behind the main fuse box in the left front kick well area where the wire from the fog lights end up.
    Sorry for the bad description but its in one of the old fog light treads. Just do a search.
