Can module from a 2016 pack be transplanted into a gen 2 case
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Al Bundy, Sep 1, 2018.
Tags:
  1. Al Bundy
    Al Bundy Member
    140
    69
    florida
    found a 2016 pack for sale and was wondering if the module can be transplanted into the gen 2 case without issues..
    (im not sure how many mods are in the 2016 pack)
    DLC82SV likes this.
  2. DLC82SV
    DLC82SV Member
    241
    119
    Good question!?!?!
    49,516
  4. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    Make sure the 2016 pack is the NiMH type and not the lithium ion type;).
    Can you drop in a gen4 NiMH module into a Gen2 pack: yes
    Will the module resemble the Gen2 cells: no
    Will there be issues: probably
    If the gen4 pack is NiMH, it will be the same size and have the same voltage rating, so it is possible.
    Hope that helps (y).
    Al Bundy and bisco like this.
  5. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    It might be possible, it might not be possible.
    For the 2016 pack, I don't k kW the battery chemistry it has. But if its the NIMH chemistry like in gen2, then it would work. But of its lithium ion chemistry, there might be issues, because the BMS of both are different.
    DLC82SV likes this.
  6. TampaPrius.com
    TampaPrius.com Active Member
    461
    296
    Tampa, Florida
    Yes, it has the same size 28, 7.2v modules. They look a little different but work fine and is a very affordable option.
    Obviously it has to be a Nimh battery.
  7. jerrymildred
    jerrymildred Senior Member
    11,516
    14,120
    Tampa, FL
    I believe @TMR-JWAP has also transplanted gen 4 Nimh cells.
    DLC82SV likes this.
  8. Al Bundy
    Al Bundy Member
    140
    69
    florida
    is the outter case marked as to the type of battery it is?
    DLC82SV likes this.
  9. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    All batteries are marked, depicting their chemistries.
    Al Bundy and DLC82SV like this.
  10. TMR-JWAP
    TMR-JWAP Senior Member
    6,237
    5,937
    Columbia, SC
    A Gen 4 HV battery pack is clearly marked on the outside if it is Li-ON or NiMH.
    The NiMH ones I have used are G9280-47200
    Dxta, Al Bundy, DLC82SV and 1 other person like this.
  11. Al Bundy
    Al Bundy Member
    140
    69
    florida
    this is the picture he sent says its not marked.. can you tell by looking? He really dosent speak english well so I dont think he knows what Im talking about.. thanks
  12. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    Text in the pan can't be seen clearly. Looks blurred.
  13. Al Bundy
    Al Bundy Member
    140
    69
    florida
    thanks, I thought they might have different labels .. I dont feel like driving to Miami to find out its wrong..
  14. TMR-JWAP
    6,237
    5,937
    Columbia, SC
    That is a NiMH label. You'll notice there are 2 yellow triangles right around the top center of the long skinny label. Directly under those triangles it should say NIMH. On the small white label, just left of the "X1" it should have the toyota part number. Most likely G9280-47200. The two photos below were just taken from a case in the shop.
    This is an ebay auction for the Li-ON style battery. Notice the difference in labels and case.
    2016 TOYOTA PRIUS HYBRID BATTERY Prius (VIN FU, 7th and 8th digit) G9510-47120 | eBay
    #14 TMR-JWAP, Sep 9, 2018
    Al Bundy likes this.
  15. Al Bundy
    Al Bundy Member
    140
    69
    florida
    thanks, i didnt think to look at e bay...
  16. exstudent
    exstudent Senior Member
    2,213
    901
    Torrance, CA
    How much is the person wanting?
    Toyota dealers selling online, have the HV Battery going for $1800+. You'll have to do your due dillegance and make sure the dealer will sell to you.
  17. TMR-JWAP
    6,237
    5,937
    Columbia, SC
    Looking at the photo in post 11, that's definitely a private owner or salvage yard. I'd be a bit irate if a dealer had my new battery sitting on pavement like that. Probably a driveway.
  18. Al Bundy
    Al Bundy Member
    140
    69
    florida
    under $1000 but its a 6 hour drive each way and its sold as-is.. i want to open before i buy to make sure its not out of a flood car
  19. Al Bundy
    Al Bundy Member
    140
    69
    florida
    they stip copart cars with cert of destruction..just worried its a flood car.. no way to tell from the pic
  20. TMR-JWAP
    6,237
    5,937
    Columbia, SC
    Flood car batteries will typically have a layer of dried dirt/mud on EVERYTHING, including inside the case. It looks pretty clean in the photo, but that doesn't mean they didn't do a little housekeeping on it prior to taking photos. Have him take the cover off the left side of the battery to expose the electronics portion. Get a close up photo of that section. If it's clean, then it's most likely not a flood victim.
    You could also save yourself a heck of a drive if they ship it to you. Probably be $75-150 for one battery depending on their relationship with their freight shipper.
