Can PHEV electric motor accelerate for traffic flow?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by mainerinexile, Mar 12, 2011.
  1. mainerinexile
    mainerinexile No longer in exile!
    403
    73
    Maine
    For those who have driven the PHEV, is the electric motor, or power to the electric motor, better than the Gen 3 Prius? The issue is that the Gen 3 electric motor really can't accelerate in traffic to keep up with other traffic. If one accelerates from a traffic light to stay up the rest of the traffic, the ICE always comes on. If this is the same in the PHEV, won't the ICE run often in traffic?
  2. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
  3. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
  4. cproaudio
    cproaudio Speedlock Overrider
    2,401
    758
    CA
    I test drove the PHEV once. The PHEV version of the Prius has enough power to accelerate at the same pace as rest of the traffic. To get a feel of how the PHEV accelerates on your own prius you can try this. Warm up the car first by drving at least 5 miles or more. If you have scanguage, the engine temp should be at least 70C or 156F. The hotter the engine is the more likely it'll stay in EV mode. Once your engine is warmed up enough, you need to get 7 bars on your battery meter. You can do this by regen from 50mph to stop a couple of times or regen from an overpass. Once you've got a warm engine and 7 battery bars activate both EV and PWR mode. Now, accelerate with HSI just to the left of PWR bar. The ICE will kick on once you hit 25MPH. Now imagine this, the PHEV can accelerate faster and up to 62mph.
    Here's a video of PHEV's acceleration, skip to 2:30
  5. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    Or, get warmed up, get seven or eight bars and then shut down. now pull fuse no. 37 (could be different in US cars. it's the fuse under the hood responsible for the fuel injection system). Start up, and you'll get "check hybrid system". Now floor it. it's pretty fast. the PHV is faster.
  6. mainerinexile
    403
    73
    Maine
    I'm glad to hear that the PHEV can stay in EV mode and keep up with traffic. But what is different from the Gen that allows it to accelerate better? Its the same electric motor, right? Would the Gen III behave the same way if the computer didn't kick it out of EV due to 'excessive acceleration'? If you really goose the PHEV, will it also give the excessive acceleration message and start the ICE?
  7. john1701a
    john1701a Prius Guru
    12,748
    5,243
    57
    The cordless Prius under-utilizes that electric motor. There's greater potential available than what the low-capacity battery can provide.
    Being able to accelerate up a long & steep hill in my neighborhood from a dead stop at the bottom to 40 MPH, then maintain that speed with the greatest of ease without starting the engine, was the ultimate demonstration. I drove the PHV around the valley 3 more times after that first attempt to verify how hard I could push the EV. Every time was a pure delight.
    It's proof of how well thought out Toyota designed the system... lots of opportunity from an extremely flexible set of components.
    2 people like this.
  8. Tideland Prius
    16,066
    It won't give the "Excessive Acceleration": message because there is no "EV Drive Mode" button. It defaults to it after being plugged in so just think of it as normal Prius operation but instead of the engine kicking in after the middle line on the HSI, it kicks in when you enter the PWR region. And instead of kicking in at 25mph, it kicks in at 62mph.
    But yes, if you do require greater acceleration, the engine will kick in to assist but will revert back to C-D mode the moment the power requirement drops.
    2 people like this.
  9. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    At 2:30 in video, I clocked you about 19 seconds from 0 to 50 MPH in EV.
    This is a very good topic because it raises the question -
    can you do the short trips up to 40 and 45 MPH boulevards, fit in well with traffic and not invoke the ICE? Sounds like the answer is yes.
    Obviously with this car, you would want to make it as convenient and easy as possible to plug in, because you may be doing it a lot.
  10. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    Ummmm, something like 200 lbs? or so more of battery (2 EV, 1 hybrid pack) which are also Li-ion (more power for its size).
    The PHV's battery fills up the spare tire and cargo tray area, plus the load floor is lifted a couple inches. IOW, it's a much bigger battery.
    It's all about the battery in EVs. That's what supplies the power.
    Gasoline has MUCH higher energy density than batteries, unfortunately. Not sure I said that right, but gets the picture across.
  11. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    Yep. As Elon Musk, CEO of Tesla stated, the 1000 pounds of batteries in a Tesla Roadster has only the energy content of ~2.5 gallons of gasoline. I posted about it at http://priuschat.com/forums/tesla/67655-charlie-rose-interview-elon-musk-tesla.html.
    2.5 gallons of gasoline weights ~15.75 lbs.
