Can someone add the touring freature to the base
Discussion in 'Gen 2 Prius Main Forum' started by CheapChic, Mar 26, 2007.
  1. CheapChic
    CheapChic New Member
    40
    What does the Touring have that can be added to the base
    They must have made the touring to accomondate the people that wanted better handling.
    Anyone know of lowering kit for this car
  2. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    The differences are:
    1. Stiffer suspension.
    2. 16" wheels.
    3. Larger rear spoiler.
    1. You can get a TRD suspension for the Prius. You can also add the BT stiffening plate.
    2. 16" wheels are not hard to find. Try to stick to ones that are as light as or lighter than stock.
    3. I'm sure you can buy the spoiler from the parts dept. of your favourite dealer.
    It's less expensive to buy a Touring model, than to "upgrade" the standard model. Similarly equipped, a touring is about $300 more than a standard model. The TRD suspension is over $1000 by itself. Wheels would cost in the $1500 range with tires. I don't even want to know how much the parts dept. will charge for the spoiler. ;) You may even be able to trade in your standard for a touring for less overall than the "upgrades".
  3. Tideland Prius
    16,151
    Yep, what David said. You can buy the 16" Euro wheels and "Type-B" spoiler from Sigma Automotive.
    You can't get the exact same suspension but you can install TOM'S or TRD's suspension set.
  4. mcbrunnhilde
    mcbrunnhilde Opera singin' Prius nut!
    612
    23
    Doesn't the Touring model also have VSC and HID headlights? MUCH better just to buy the Touring model!
  5. brick
    brick Active Member
    1,083
    78
    Upstate NY
    She should already have VSC and HIDs on her '07 since it's a package 6. I went for package 2 specifically to get the VSC program.
  6. itsme
    itsme New Member
    68
    If you need a lowering kit you should have my prius, it hits every speed bump and parking curb, I wish it was jacked up... but I was used to a 4x4 too.
  7. CheapChic
    40
    THANKS!
    I don't want to lower, just better handling.
    Where can i get the trd set up, and does it lower it or just give a better ride.
  8. David Beale
    5,963
    1,981
    Edmonton Alberta
    <div class='quotetop'>QUOTE(CheapChic @ Mar 27 2007, 05:30 AM) [snapback]412823[/snapback]</div>
    Talk to your friendly Toyota parts man. He should be able to give you all the details. Or search online. I looked a few months ago and as I recall, it lowers the car a tiny bit and stiffens up the suspension.
  9. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    There's also the rear disc brakes.
  10. Charles Suitt
    Charles Suitt Senior Member
    1,637
    16
    Dallas TX
    <div class='quotetop'>QUOTE(htmlspinnr @ Mar 27 2007, 10:34 AM) [snapback]412963[/snapback]</div>
    The 2007 Prius Touring Edition does not have disc brakes on the rear wheels. The ARIZONA sun must've overheated your memory. :D
