Can someone check these 2008 Gen II 12V battery numbers for me?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by DamoRC, Nov 27, 2011.
  1. DamoRC
    DamoRC New Member
    So Cal
    I have a 2008 GenII Prius, 40K miles and over the last month or so mileage seems to be dropping (based on miles obtained per tank). I think that this might just be the bladder tank holding less as it has gotten a little chilly here in SoCal. However, in trying to figure this out I came across a thread indicating that a faulty/old 12V battery can impact the MPG. So I used the test procedure documented here:
    (Oops - I cannot post the link as an actual link - but it is post 1020264 here on Priuschat)
    The numbers I got (twice) were:
    (1) No brake, power button once, enter Vehicle Signals screen = 11.7V
    (2) No brake, hit power button again to add some load - dropped to 11.1V momentarily then returned to a steady 11.4V
    (3) Depress brake, hit power button, car in ready mode, voltage displayed = 14.0V, dropping to 13.9 when ICE kicks in.
    As I said, I got identical numbers for both tests and I was checking with a voltmeter attached to the 12V at the same time (these numbers fluctuated more but were within 0.1V of the "Vehicle Signals" display. These numbers seem low compared to what was indicated in the testing thread.
    Any thoughts / comments - Do I need a new 12V?
    Thanks
    DamoRC
  2. JimboPalmer
    12,470
    6,870
    Greenwood MS USA
    Yes, you have less than 12 volts under all scenarios except when it is being charged by the HV battery. If it was over 12 volts except under load it might be good.
    49,701
    what are your display mpg's and calculated mpg's? miles per tank is meaningless.
  4. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    Yes. You could try putting it on a trickle-charger at 4 amps or less for a few hours, letting it sit overnight, and then repeating the test. It could just be low state of charge, but usually for those numbers, it will be dead/no start soon.
  5. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
  6. DamoRC
    DamoRC New Member
    So Cal
    Understood. Question is regarding the battery health.
    Thanks,
    DamoRC
  7. bisco
    49,701
    right, and you're going about it the right way. but as a symptom, you would be best served to understand and track mpg's properly as well.
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,809
    Clearwater, Florida
    Very poor numbers under load. Death is imminent. Usually at the most inopportune time. I suspect it has been jumped before.
  9. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    It is recommended, even on normal car batteries to charge about every six months. Since the Prius 12V/ charge system is so anemic, this recommendation goes double. If you think I am blowing hot air, just research all the threads on Priuschat, on problematic 12V Batteries.
  10. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Low numbers indeed. Do you have a voltmeter so you can test the battery with the car completely off?
    One of symptoms for a dying 12v battery is the engine will continue running even when stopped when it would normally turn off if the battery was good.
