can someone please tell me whats the difference between obd1 and obd 2
Discussion in 'Generation 1 Prius Discussion' started by evnz, Apr 9, 2013.
  1. evnz
    evnz New Member
    1998 Prius
    i was wanting to know so when i see it i can i.d which one it is
    thanks
    owen
    and if anyone has wiring diagrams for them it would be grate
  2. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    OBD2 has been in effect since MY96 of every car sold in the U.S. Search Wikipedia for more details.
  3. SteveWlf
    SteveWlf Old-on-Hold
    262
    33
    Montesano, WA
    Well, you model year is going to tell you which you have. The Prius, being make since 2000 will always have the OBD2 and the later Prius had OBD2 but with much of the data on the CAN bus not readable from some of the cheaper OBD2 readers. I have a fairly good/expensive OBD2 reader has worked on most all cars until I got into the Prius, Gen2. Worked to some extent on the Gen1 and gave me some of the P3xxx codes. However, on the will only read the non CAN bus code apperantly.
    If you need a better discription of the CAN bus data format, I will leave that to someone else.
    Steve
  4. bwilson4web
    15,389
    Wiki is a good place to start. Then search the vendor sites for chips that speak OBD. Their application notes will give you more details than you can image.
  5. maestro8
    maestro8 Nouveau Member
    471
    109
    nor cal
    The difference is 1.
    OBD 1 + 1 = OBD 2.
    How would it grate?
