Can someone recommend a radio with an Aux/MP3 input
Discussion in 'Gen 2 Prius Audio and Electronics' started by ericisbacchus, Oct 5, 2016.
  1. ericisbacchus
    ericisbacchus Junior Member
    91
    Kansas City
    We've got a 2005. I think it's a model 4...All it has is a single-disc CD player. No Aux/MP3 input of any kind.
    Can someone recommend a (hopefully cheap) replacement radio with an Aux/MP3 input? I don't care about CD player or tape player. Although...with a tape player, I could put one of those connector tapes in there. Hmm...
  2. JC91006
    16,468
    8,383
    You can check eBay for a stock unit from maybe a 2008 prius, which should have aux output on the radio
  3. JC91006
    16,468
    8,383
  4. Kevin_Denver
    Kevin_Denver Active Member
    581
    421
    Denver, CO
    If you haven't thought about them, you have 3 options really:
    1. Aftermarket CD player - two options here - replace stock CD player with a double DIN using a kit or put in a stealth CD player where the current plastic "cubby" is below the CD player. It fits a single DIN perfectly, just need a couple of screws (I know because I did this on mine). Be sure to see this thread for getting the right wiring adapters: Stealth install an aftermarket stereo in Prius | PriusChat
    2. Drop in a CD player from a later model Prius with Aux in (I think 2007 and later, could be 2008). Obviously, you'll need to install the aux in cable/port as well.
    3. Add an aux in to your existing player. A poster in this thread was able to do it: Cheap and easy way to add Aux input on '05 Prius? | PriusChat There are several companies out there that offer kits; do some additional Googling if you're interested.
    If you're going with option 1, I'd just look for a name brand CD player with at least 10W rms output per channel with a 1/8" input. Something like this. Definitely no need to spend more than $75 for a quality CD player these days. Consider getting one with a USB port that can read thumb drives if you might use it. This is really nice feature these days.
    Also, check that you don't have the JBL system. If you have the JBL system the speakers have too low of a resistance and aren't compatible with 99% of CD players. You can tell you have the JBL system by a middle channel speaker being there that's behind the center screen . If you have a JBL system and just want a line in, I'd go with option 3.
    #4 Kevin_Denver, Oct 5, 2016
  5. ericisbacchus
    91
    Kansas City
  6. JC91006
    16,468
    8,383
    Look at the picture I posted with the aux button on the radio, your eBay one doesn't have aux button
  7. ericisbacchus
    91
    Kansas City
    I see the aux button...but where is the actual aux input? I don't see it...
  8. Kevin_Denver
    581
    421
    Denver, CO
    On Pri-i like mine, it's inside the arm rest storage between the two front seats. So you would need to get the cable or a 1/8" plug for it (but not necessarily install it in the middle armrest.
    The sound quality on those tape adapters isn't very good. If you're going that route, just get a well reviewed 1/8" fm transmitter and use your current deck. The sound quality will be about as good, at a much lower cost. It's probably worth trying first anyways and you can decide if the sound quality is good enough for about $20. Just don't buy a super cheap one of these - go with one that's well reviewed.
  9. ericisbacchus
    91
    Kansas City
    I reckon this is the route I will go. While I'm here, can someone recommend some speakers that will fit in my car that are cheap? Anything would be better than the awful stock ones in there.
  10. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    I use something similar to this in my 2005. It's not the greatest of quality but it gets the job done cheap and easy.
