Can someone show me how to remove the license plate lighting plastic?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by anthofang, Apr 24, 2009.
  1. anthofang
    anthofang New Member
    56
    Los Angeles
    i need to remove the plastic so i can replace the bulb
  2. Tideland Prius
    16,445
    Pull hard. There are 7 or so clips so it'll take some strength the first time you pull it out. You may or may not break some clips. I didn't but some have.
  3. ken1784
    ken1784 SuperMID designer
    2,943
    1,381
    67
    Yokohama, JAPAN
    Are you going to remove the clear plastic cover from outside?
    It is done from the inside to replace the bulb.
    Prius License LED
    Ken@Japan
  4. yardman 49
    yardman 49 Active Member
    606
    77
    Northern Kentucky
    Look in the back of the Owner's Manual. I believe that you will find the procedure in there for changing the bulb.
  5. Tideland Prius
    16,445
    lol.. have you seen the owner's manual? It just has an arrow pointing away from the big black plastic piece behind the hatch.. Yes that is the motion but it's awkward to interpret at first.
  6. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    The service manual says that you should first detach each clip with a screwdriver tip that's been taped (I guess to reduce gouging and scratching of the plastic). But I can't tell how you're supposed to get to each clip. See page ED-44 of this PDF:
    http://www.hybrid-synergy.eu/Documents_2006/ED%20-%20Engine%20Hood%20Door.pdf
  7. darelldd
    6,059
    389
    Northern CA
    Here's my page on it.
    Prius License LED
    Ah... I see Ken beat me to posting my page. ;)
  8. patsparks
    10,664
    567
    Adelaide South Australia
    Good job there Darell, I like it.
  9. Tideland Prius
    16,445
    Hmm...weird... I have no idea how'd you do it.
  10. darelldd
    6,059
    389
    Northern CA
    In some ways, the manual is useless. This is one of them. :(
    Did you notice the Australian beer? Just in your honor.
  11. Patrick Wong
    18,200
    6,493
    No need to use a screwdriver, whether with taped tip or otherwise. Just grab one corner of the black hatch panel and start pulling. As the blue clips release you can see how much force is required to detach them.
    When I remove the plastic hatch panel, all 11 blue clips remain on the panel.
  12. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Maybe a video would help?
    [ame=http://video.google.com/videoplay?docid=759307614248005541]How To: Change Prius License Plate Light Bulb (to LED)[/ame]
    3 people like this.
  13. Tideland Prius
    16,445
    Good stuff usb! Is that in the KB?
  14. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
  15. Tideland Prius
    16,445
  16. BassInstinct
    BassInstinct Junior Member
    17
    Mid-Atlantic
    Any thoughts about removing those clips that DID stay behind in the hatch? I have about half in the panel and half in the hatch. Bought replacements just in case, but having difficulty getting remaining clips out of the hatch. The new bulbs (blue LED from superbrightleds.com) look great, but what a bear to put in!
  17. macmaster05
    macmaster05 Senor Member
    4,050
    730
    AH HA! This is the bane of the whole process. First you need is a clip tool (something that looks like this):
    Left end of the is the part you want. Ignore the right side.
    1) You can also try a big flathead screwdriver but the idea is that you need good leverage to pull out those remaining clips. A clip tool makes the job much easier. Wedge the opening of the clip tool between the top of the clip and pry it just enough so that only one side of the clips get loose. Now you have to wiggle it back and forth to continue loosening it. Sometimes the clip will settle back in its original position so it can be incredibly frustrating. You'll have to give it one last really hard pry to fling it out. The important thing is to not break the top of the plastic clip while doing this. If you do, try not to do it again on the same clip; If you mess up twice, you can imagine that you'll be left with a nub and nothing to pry against. Also note that you may scratch the metal panel a little using the clip tool with such force, but I figure nobody sees that anyway.
    2) Another, much easier method, is to push the clips out from the inside, but this only works for a few of them. Where there is a hole in the metal hatch big enough to slide your tool in, you can press the plastic clip out by applying downward force. I actually found it helps if there are two holes so you can grab the tool with both hands and pull down with maximum strength. Either way you'll need to press hard again, but at least this way you definitely won't snap any plastic trying to pry.
    Notice the one on the left got chewed up quite a bit, but I barely got it out without breaking the whole thing off. The one on the right is faced the wrong way but I completely broke it to a nub. Luckily, I realized I could remove it via method 2 as I described.
    You'll notice that if you do it correctly and get them out, you can reuse it! :) You won't even need your replacements. So slide them back on the plastic panel and remember to scold them to never do it again. When I did this I had 6 stuck clips but managed to salvage 4. I broke the 2 shown above, and replaced them with the ones I bought from Toyota.
    Now, some people have said that you can leave them in there and just snap your cover back on the hatch, but the ones that you didn't bother to remove and replace will never slide in like they were originally. I chose to do it the hard way as described above, because I couldn't stand the thought of potential rattles.
    The good news is that if you ever need to pull of the panel again, the pieces come off much better the second time and if some don't, you'll know how to do it now. :)
  18. batonrougewes
    batonrougewes New Member
    Baton Rouge
    Needle nose pliers!
    About five blue clips remained in the metal grid after I pulled off the large plastic panel. However, I found it quite easy to torque them off using a pair of needle nose pliers. And I did no damage to the clips in the process.
    Just slide the pliers between the top of the clip and the wider bottom section, so that you are grabbing the clip like a dog would grab a pup - by the neck. Then leverage the plier handles against the metal grid - voila! The clip pops right out with no trouble.
    I also used needle nose pliers to twist and pull out the light fixture, once I'd unplugged the wiring from the light fixture. Easy as heck.
  19. drew935
    drew935 Member
    168
    23
    Nor Cal
    Upholstery panel remover tool is what you should use. I have 3 of them: one plastic and two metal ones.
  20. garglo
    garglo Member
    99
    45
    Port St Lucie, FL
    2020 Prius Prime
    Once I had the panel off I used a little silicon spray to lub the blue pins. Worked so well I put it on all the pins before putting it back together. Pulls off much easier now and all pins stay in the panel.
