Can Speedometer be adjusted
Discussion in 'Prime Main Forum (2017-2022)' started by Ridge Kennedy, Oct 19, 2020.
  1. Ridge Kennedy
    Ridge Kennedy Junior Member
    I purchased a 2020 prime in November. On my first (six-month) service I told the Toyota service department that the speedometer was reading two mph too fast. My GPS and several local "your speed is" working signs all agreed. When I was actually traveling 25 mph (per GPS and speed limit signs), the speedometer was reading 27 mph. The service dept. told me that there was no way to change this. Is that true? Thanks. Ridge (in New Joisey)
  2. schja01
    schja01 Senior Member
    1,820
    1,207
    Chicagoland
    2024 Prius
    Limited AWD-e
    Every Toyota I’ve owned read 2 miles high. There are several discussions on this exact Item in the forms. Personally I think it’s an appeasement to the Toyota lawyers.
    51,141
    yes, it is true. you could change tire diameters though
  4. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    I noticed a few weeks ago that our 2008 Pontiac Vibe's speedometer shows 2mph higher than indicated by the GPS app on the phone.
  5. fuzzy1
    10,335
    This question about an industry standard practice is so common, we should make a Sticky thread about it.
    Here is a really old article on this, from 2002:
    Speedometer Scandal!
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,798
    2017 Prius c
    Make that every car made in the last 30 years or so.
    The only semi-reasonable way to "fix" it is to change the size of the tires.
    The real fix is: Don't worry about it.
    It might keep you from getting a speeding ticket some day.
    MTN likes this.
  7. CharlesH
    2,796
    1,162
    Roseville, CA
    The usual explanation for why speedometers read high is that the manufacturers don't want owners to complain about getting speeding tickets when the speedometer said they were under the speed limit. If you look at the speed on the OBDB-2 bus, that will have the correct value, but the speedometer display is deliberately programmed to bump it up a bit.
  8. bisco
    51,141
    i just drive 2 over
  9. bisco
    51,141
    but does this deliberate miscalibration make you reach warranty miles sooner?
  10. Mendel Leisk
    40,575
    No. Only the speedo reads high, not the odo.
    MTN, TGrracie, Henrik Helmers and 2 others like this.
  11. bisco
    51,141
    good news, thanks!
    TGrracie and Mendel Leisk like this.
  12. fuzzy1
    10,335
    No. And there are multiple class-action lawsuits that enforced this, claiming warranty fraud. Now my new Subaru odometer reads a little bit low, the opposite behavior of its speedometer.
  13. Trollbait
    12,346
    The OEM tire was a little bit smaller than what you're using now, or they calibrate it for worn tires.
  14. Mendel Leisk
    40,575
    I'd suspect with odo they do their level best to get it accurate, say consider the spec'd tire size's revs per mile half-way between brand-new and down to wear bars.
  15. Trollbait
    12,346
    I was thinking they have set for worn factory tires, in order to avoid being sued,
  16. fuzzy1
    10,335
    I was thinking the error in mine was too large for just worn tire allowance.
    Tips likes this.
  17. Kenny94945
    Kenny94945 Active Member
    842
    418
    Sausalito
    2016 Prius v wagon
    Some cars, maybe not a Prius, one could buy aftermarket speedometer cable gears to correct a mph difference.
    I would believe the dealer that this is non adjustable, especially noting laws concerning odometers.
    Yes, there seems an industry variance on all speedo readings .... I recall 5% is a norm.
    2 mph is very close and the fine tuning maybe chasing one's tail.
    Tire diameter as the tire wears would also create a variance.
    Best of luck wished.
  18. Trollbait
    12,346
    Was Subaru one of those sued over warranty and odometer readings?
  19. fuzzy1
    10,335
    Yes. Of my household's stable, Honda was hit first, then Subaru. My current Subaru is post-settlement. No new Hondas, that was replaced by my first Prius.
    That cable gear-change era ought be to nearly done now, as the cables and gears disappear, replaced by pulse counters somewhere on a drive shaft.
    #19 fuzzy1, Oct 21, 2020
  20. CharlesH
    2,796
    1,162
    Roseville, CA
    This was an important point for the regulators. In the old days, the speedometer and the odometer were mechanically linked, so tweaking one would tweak the other. Now it is all computer data, so they can program each device like they want. People who have dug into this have found that the correct speed information is on the OBD2 bus, and and can thus be recorded as needed to comply with regulations.
    #20 CharlesH, Oct 23, 2020
