Can the aux battery be disconnected from under the hood?
Discussion in 'Gen 3 Prius Main Forum' started by labumm, Nov 30, 2023.
Tags:
  1. labumm
    labumm Junior Member
    62
    The purpose of this post is to see if there is an alternate method to reset the computer than disconnecting the aux battery ground terminal. The second purpose is to provide another account of this issue. I know this is not novel. I was reading a number of post as I sat in the car working on this problem. Having experienced low aux battery voltage issues many times, I know that if the warning/error behavior make no sense, it's probably that.
    Let me explain why and what I am asking.
    I don't drive that much and my aux battery tends to discharge over time, so I have a connector in the rear compartment put it on a charger at home. Or add another battery in parallel in a pinch so I can just go and charge later. Unusually there are advance warning signs of low aux battery voltage, like taking longer to get the ready light. At this point I'm probably just nursing the aux battery along, but that is not the point.
    Yesterday I went get in the car. I couldn't get to ready. I had the triangle warning and the flashing green park LED. The car thought I was not in park. So it wouldn't turn it off fully (orange light on "on" button, gear display not going off). [This car does not have the flat panel display, just the combo meter.] Worse yet I couldn't lock the car. If I removed the key fob the car made the continuous warning tone outside the car. I had put the aux buttery on the charger, but that did not solve the problem. I also measured ~14.6V at the 12V terminal in the fuse box. I could leave the car unlocked, probably no one would get around to stealing anything, which I'd be wiling to do-except the tone would draw attention to it. On the other hand, leaving an unlocked car with the key fob in it seemed like a worse idea, even though it wasn't drivable.
    At this point there was one option. Disconnect the ground terminal of the battery. That could either reset the computer so I could lock the car normally and leave the battery charging and connected. Or lock the car manually so I could at least walk away and deal with it later. As you know opening the hatch of the unpowered Prius can be unpleasant. I was fortunate in that disconnecting the aux battery for a minute and reconnecting solved my problem. But for the future, is there a fuse that I can pull that would serve the same purpose--either to reset the computer or disconnect the aux battery. If the latter, that would save opening the hatch from the inside.
  2. ChapmanF
    18,478
    The quick answer to the title question is: pop the hood, take the cover off the fuse box, and unplug the fat white wire. That's the one that comes from the aux battery in back.
    The trouble with saying stuff like that is it gets picked up by other readers on PriusChat and repeated willy-nilly, overlooking one crucial fact: it's far more common for a person to see warning/error behavior that makes no sense to him or her than to see behavior that really makes no sense.
  3. labumm
    62
    Thanks. I was looking at that large gage white wire. That seemed the obvious choice. But I was not seeing any annotation on the box lid.
    I see your point about my statement. There is simply no way to accounting for that. It presents a constant source of amazement.
  4. labumm
    62
  5. Gourockian
    Gourockian Junior Member
    75
    23
    New Port Richey
    I used to have the same problem with the 12V aux battery discharging in my wife's Ford C-Max Energi (plug-in hybrid). These cars are notorious for phantom discharging so after being locked out of the car a couple of times, my first solution was to hook up a trickle charger connector to the under-hood 12V terminal and a good ground point. This was then led out through the front grill and zip-tied to prevent it falling back inside but with enough slack to allow it to be pushed in almost out of sight. I was then able to hook up the charger without opening the hood or rear hatch.
    However, after a few months, I decided to change tactics and for what it's worth, the simple solution I found was to place a small solar panel in the rear quarter window and connect it directly to the battery. This car was not garaged so being in the Florida sun, it produced around 18V (unloaded) and 11V when hooked up. It attached to the glass using the four plastic suckers which were supplied. Mine came with various connectors which allowed it to be hard-wired to the battery and since then, there have not been any issues with it discharging. I wouldn't hesitate to do the same with my Prius if I have issues with the aux battery. Here's a link to a similar item:
  6. Mendel Leisk
    41,846
    I sometimes wonder what "could" be done, by the manufacturers. They must already have some sort of flash memory, to store the odometer number and a few other bits of info. If they could have that memory retain everything that needs remembering, and summarily disconnect the 12 volt battery every time the car's shut down, no more phantom draw.
    Even though I've got memory saver capability, more often than not I disconnect the 12 volt completely, for brake work (to avoid a caliper piston possibly popping out). I've noticed subsequent to doing that, the car does a strange rev-up, for the next few starts, recalibrating something.
  7. ChapmanF
    18,478
    What, no more remote fobs or keyless entry or pushbutton start or "where's my car"? Oh, the humanity!
  8. Mendel Leisk
    41,846
    Yeah, and dumb keys, that you can dupe for $5~10 at the shoe repair, lol.
  9. CR94
    CR94 Senior Member
    2,740
    1,198
    Northwestern S.C.
    Then how would the car time the brake test that automatically happens ~2 minutes after shutdown, or the fuel vapor plumbing test that runs 5 hours after shutdown? That's in addition to the items ChapmanF mentioned.
    I don't understand the bit about needing to disconnect the battery to avoid brake pressurization. My car never does that except shortly after parking, or if the driver's door is opened or the brake pedal is pressed---all of which could be easily avoided during brake work.
  10. ChapmanF
    18,478
    I've at least once caught myself about to open the driver's door for something, then walked around and gone in through the passenger side.
    Maybe some painter's tape over the driver's door handle....
    CR94 likes this.
  11. CR94
    CR94 Senior Member
    2,740
    1,198
    Northwestern S.C.
    The door can be locked, which should eliminate any risk of absentmindedly opening it, assuming the key fob is far away.
  12. Mendel Leisk
    41,846
    One thing, after having the calipers off, when everything is back together and before reconnecting the 12 volt neg cable, I like to tromp the brake pedal multiple times, to reduce pedal travel, travel which might be detected by the car, causing a code. I suppose I could slip in through passenger door, reach over, to avoid the drivers door opening trigger. Still, I’m belts-and-braces, hate getting so close to something that any slip-up could be disastrous.
  13. ChapmanF
    18,478
    To be honest, I haven't seen any reason (in Gen 3) to be concerned about any automatic action of the brake system while the car is off, other than the self-test that applies pressure to the wheels, 90 seconds on the nose after the car is powered off. I have not stumbled on any other way of triggering that test.
    Mere operation of the pump, to restore pressure in the accumulator, doesn't budge any caliper pistons, unless there is some pre-existing problem where system pressure is getting to the brakes when it isn't wanted, which you would likely notice as drag while driving the car. And if that were an issue, the piston would start extending immediately when you take off the caliper whether the pump runs or not. The only way to avoid that would be to zero down all the stored pressure before beginning work.
    CR94 likes this.
  14. rjparker
    rjparker Tu Humilde Sirviente
    10,428
    6,535
    Texas Hill Country
    A good 12v battery with a normal (eg low) parasitic draw should last three weeks or more and still Ready the car.
    If you only drive every two weeks and then 15 minutes total, the car may not fully recharge the battery and you are heading for lower capacity and more trouble. A staged maintenance charger then makes sense.
    If there is more than 25 ma of parasitic draw, most don’t know it and blame their driving habits or the battery. Measuring parasitic draw is key.
    Most likely if there is a problem requiring a disconnect power cycle, the problem needs to be diagnosed and repaired.
    Driving the car twice a week is the real answer and reduces other storage induced issues like flat spotting tires, condensation in the oil and corrosion buildup.
  15. Mendel Leisk
    41,846
    Yeah we're driving once or twice a week; mostly longer drives, 50 kms round trip. And back on a charger in-between.
  16. Mendel Leisk
    41,846
    There's been reports here though, owner's DIY'ing brake maintenance, and having the pistons pop out.
  17. ChapmanF
    18,478
    Reconciling those reports with knowledge of how the system works is always the tricky part ... easier, the more details are available in the report.
    If the brake self-test occurred while a caliper was off, certainly the piston would be ejected.
  18. CR94
    CR94 Senior Member
    2,740
    1,198
    Northwestern S.C.
    At that stage, you could safely unlock the door, and not have to play contortionist climbing over the console and flying buttress.
