Can the gas tank be "burped"?
Discussion in 'Gen 2 Prius Fuel Economy' started by DonDNH, Aug 17, 2004.
  1. DonDNH
    DonDNH Senior Member
    1,711
    654
    Nashua, NH
    Four Touring
    Today when I filled up the pump shut off after 8.2 gallons. According to my estimate, I should have taken at least 9 gallons.
    I removed the nozzle, and rocked horizontally the car by pushing to the right of the filler cover and just below the spoiler until the car was swaying and I could hear the gas sloshing in the tank.
    Then, the tank burped!
    I then proceeded to add nearly another gallon with no difficulty.
    Has anyone tried this with their baby?
  2. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    I've tried rocking. Doesn't help much. Instead, I fill slowly, and let the vapors gurgle out between pauses until I get fuel right to the filler neck (or somewhat close). I've learned to get it to the point where it doesn't spill, but it takes practice and a cooperative nozzle.
    There's supposed to be a means of purging vapors into the intake manifold, however I question whether or not it works in the case of fillup.
    I'm hoping rather that Toyota will release a "fix" (i.e. an updated filler nozzle) to remedy this so we don't have to manipulate the tank in various ways to get a complete fill.
    On a different note, about a minute or two after I park, I hear some sort of "release", but that's followed by the hydraulic brake pump, so the release may not be fuel tank related.
  3. Batavier
    Batavier Member
    442
    The Netherlands
    I sometimes do this with my current car (only my current car for two more days... then it's Prius time!) and it can help a bit. Especially if the filling station isn't on level ground and the car is 'leaning' to the right where the tank opening is located.
